Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Column footing size
Column footing size
Wed Dec 09, 2015Total posts : 8
Pooja
Pooja
Topic: Column footing size
What should be the minimum size of square footing for 9*9 column under 9" thick wall and under 4.5" thick wall?
Thanx
Wed Dec 09, 2015Post  #1
Please check with an structure engineer for better picture. It depends upon the number of columns and their location.
Wed Dec 09, 2015Post  #2
Pooja
Pooja
Okay Sir,
But I just asked standard norms, please answer if you can. it will be 2 storey house and one room only at thetop( back side)
Wed Dec 09, 2015Post  #3
Dear Pooja
       The size and design depends upon the distance of the column and load taken by the column and structural engineer design after consideration all the aspects including earth quack. As you said standard design how can be standard for room it may be 10',11, or 12'. How ever take footing not less than 5'x5'.
Thu Dec 10, 2015Post  #4
Pooja
Pooja
it is 22.5* 40 sq. feet plot. 10 columns center to center distance not more than 10 feet. soil is hard. maximum room size is 10*11
Fri Dec 11, 2015Post  #5
Dear Pooja
             You can lay footing as given earlier 5'x 5' with 9'' thickness with cement concrete 1:1.5:3 ratio.which is safe as per earth quack measure.
Sat Dec 12, 2015Post  #6
5'x5' for 9" is the best.
Sat Dec 12, 2015Post  #7
Pooja
Pooja
one of the engineer working in MES said that projection should be less than or equal to thickness. In no case projection should be more than thickness. Comment please
Mon Dec 14, 2015Post  #8
Dear Pooja
    Your question is not clear, write in detail about the information.
3508
6548
3793
2718
3275
2832
how to make footing and column for g 2 building on water well
Last answer on 4/1/2013 7:09:40 AM. by Arun. Forum started by Arun
2045
SIze of Footing in black soil
Last answer on 11/12/2013 11:22:13 AM. by S L Gupta (Civil Engg). Forum started by Purvi Panchal
15780
9001
6440
Column placement for house
3017
2259
m15 cost vs m20 cost
10047
3156
WANT TO SEE PLANS PLOT SIZE (50 FEET X 23 FEET)
Last answer on 9/9/2014 12:29:01 AM. by seema tyagi. Forum started by amit sharma
3816
WANT TO SEE PLANS PLOT SIZE (16 FEET 3" X 33 FEET)
Last answer on 9/9/2014 12:28:39 AM. by anand. Forum started by amit sharma
3941
6414
3592
my plot size 18*32 feet north face 18 feet rastaplease sugest
Last answer on 10/12/2016 2:40:37 PM. by sandeep singh. Forum started by arunmishra
5811
3792
9884
2670
4627
4143
2865
5006
3655
1864
2800
2610
2372
2462
2638
1807
3607
6254
Right size cupola
What is acre
Designing
Designing a Foundation
