Column projection/Technical query
Mon Dec 28, 2015
Pooja
Topic: Column projection/Technical query
Here IRC refers to International residential code
I somewhere read as follows:
The IRC specifies that spread footings must be at least
6 inches thick and project at least 2 inches beyond the loaded
surface.
In addition, the projection must not exceed the thickness.
So, if the pier is a 12-inch concrete column and the footing
is 24 inches in diameter and 6 inches thick, you’ve met
code.
The footing projects 6 inches around the pier, exceeding
the minimum 2-inch projection, and just meeting the maximum
projection-to-thickness ratio.
You could also land a wooden column directly on a concrete footing. Let’s use a nominal 6x6. It measures 51/2 inches square, so the footing would project 91/4 inches beyond the 6x6. The projection exceeds the minimum 6-inch footing thickness, so to satisfy the IRC, this footing would have to be at least 91/4 inches thick. The reason is loads spread through a footing at 45 degrees in a cone shape (D). Concrete supported by the soil outside of this cone imposes a shear load on the footing, and such an unreinforced footing is likely to crack down the middle
If you understood and think that this is correct way, do you think that we all are following right technique?
To get full reading and helping understanding images, download attachment here
Designing Pier Footings_tcm122-1377810.pdf on Mon Dec 28, 2015,&n
Mon Dec 28, 2015
Tue Dec 29, 2015
Pooja
Post subject: Good topic
Its really a good topic if you read it once
Tue Dec 29, 2015
Yes it is.
3571
Last answer on 12/31/2020 2:31:50 AM. by
Muhammad Rizwan
2294
Last answer on 6/16/2021 11:37:22 AM. by
dnyanesh
2368
front elevation
Last answer on 4/6/2021 8:05:35 AM. by
SCK
2422
Last answer on 1/29/2022 8:02:25 AM. by
shailesh yadav
1790
like an answer to my query as it is important.drsingh
Last answer on 9/5/2010 11:55:20 PM. by
dr singh
1640
sir i have a query how can i contract
Last answer on 1/10/2016 8:48:39 PM. by
VINAY
2572
sir i have a query how can i contract my email id is vsp106@gmail.com
Last answer on 10/11/2021 4:59:19 AM. by
VINAY
2069
beam and column
Last answer on 9/26/2015 11:33:59 PM. by
Prashant kumar palei
4940
COLUMN AND STEEL DESIGN
Last answer on 1/9/2021 12:01:44 AM. by
Kaleemullah
4940
Kaleemullah
3795
Last answer on 12/2/2014 12:34:34 PM. by
hemant
15781
Last answer on 12/8/2014 6:14:14 PM. by
Deep Shrestha
Deep Shrestha
9004
Last answer on 2/15/2015 10:53:28 PM. by
Raymond
6225
Plot shape as per Vastu
Last answer on 2/26/2015 4:45:35 PM. by
Sanjeev
Sanjeev
6443
Column placement for house
Last answer on 9/13/2017 11:49:12 PM. by
sanjay singh
Parmeswar Giri
3019
Last answer on 6/22/2017 11:07:36 PM. by
Anshu
1476
Floor extension
Last answer on 11/1/2016 12:10:42 PM. by
meghraj
2039
option other than rcc deck / balcony @ residence
Last answer on 9/4/2014 7:34:32 PM. by
D.P.S
parth
2583
Re. eccentric footing.
Last answer on 12/6/2013 12:11:41 PM. by
vignesh_mp
