Home -> Forums -> Construction -> Bricks -> Concrete solid brick contents mix ratio?
Sun Nov 15, 2015Total posts : 2
Techman
Techman
Topic: Concrete solid brick contents mix ratio?
I'm planning to make concrete solid bricks on site approx. 4000 Nos for my house construction. The contractor will provide the small hand operated electric machine, mixer and labor, and the I need to supply the materials only. The labor for making one brick of size 12"x8"x6" is Rs 7/-. He told me that the number of bricks from one bag of cement can vary from 40 to 70 Nos based on strength requirements. So, please help me to decide the following points.
1)   How many first class solid bricks of size 12"x8"x6" can be produced from one bag of cement? I need only best strength for two story house with load bearing wall, and not beyond that.
2) Normally they use quarry powder not M-Sand. So, Should I use M-Sand graded for RCC work for better strength or quarry powder enough?
3) What is the ratio of mixing the contents ie. Cement, Baby metal, M-Sand/Quarry powder, water?
Thanks in advance.
Mon Nov 16, 2015Post  #1
Dear Tackman
     In my view your contractor giving wrong calculation. If you use Cement concrete ratio 1;2;4 than you will get 12''x8'' x6'' size  bricks 20 to 22 nos If you use Ratio 1;3;6 than you will get 30 to 32 nos
  Use sand which  is coarse sand not fine sand and silt contents should be not more than 4%
Fine aggregate/ coarse sand consists of natural sand, crushed stone sand or crushed gravel stone dust. It should be hard, durable chemically inert, clean and free from organic matter, not containing any appreciable amount of clay balls or pellets and other harmful impurities i. e. alkaline, salt, mica, decayed vegetation, lumps etc.
It should be passed through I. S. Sieve 4.75 MM. It should have the finest modulus 2.50 to 3.50 and silt contents should not be more than 4%. Coarse sand should be either river sand or pit sand; or combination of the two. It should be obtained from Badarpur Sand or Stone dust obtained by crushing hard stones or gravel. It should also be obtained from river bed such as Tajewala , Dadupur sand.
Note: In general the sand particle should be coarser and have minimum silt contents. The silt contents should not be more than 4%.
Caution:
The quality of the sand has more impact on the strength of the structure inspite of the quantity of the cement used.
1) If there is more silt in coarse sand, the strength of cement mortar is reduced from 1 % to 30%.
2) If you take best quality coarse sand, it will give maximum strength.
Tue Nov 17, 2015Post  #2
Good to know.
1763
1457
1340
3791
4365
WHAT IS THE RATIO
3767
2414
roof concrete
2413
3769
concrete mix design software
3275
3456
3841
1797
3144
Last answer on 8/16/2013 1:12:41 PM. by S L Gupta (Civil Engg). Forum started by K S SHYAM SUNDER
2991
2062
cement : sand:stone ratio
5134
Use of Solid Concrete Bricks
2676
7512
Brick Advice Urgent
2879
Bricks
2793
brick calculation
2565
Cost of Brickwork
4894
2821
2349
3172
bricks
5658
3233
5134
1624
1340
1844
1479
1797
2965
fly ash bricks
2228
1723
Concrete Mix Ratio
Ready
Ready Mix Concrete
Cement
Cement Concrete
Water for Construction
CONCRETE
