Home -> Forums -> Construction -> Start Construction -> Constructing horizontal rcc belt just below windlow level for earth quack resistance?
Sun Oct 25, 2015Total posts : 4
Vinod
Vinod
Topic: Constructing horizontal rcc belt just below windlow level for earth quack resistance?
I'm building a new house in kerala (seismic zone III), and following the traditional building practice, ie. Rubble foundation+RCC belt+concrete brick wall+ RCC Lintel+ Concrete brick wall+ RCC roof, due to non availability of earthquake resistant building materials ie. bricks with holes for vertical reinforcement etc and technical expertise.
I've read somewhere that an additional horizontal RCC belt same like lintel band just below windows level covering the whole house with breaks at door locations only improves earthquake resistance. ie. Another rcc belt in between foundation belt and lintel band. Is it true? I've also read that horizontal rcc band is required only if wall height is more than 7 feet. So, please advise on whether there is any advantage on going for additional rcc belt for earthquake resistance.
Sun Oct 25, 2015Post  #1
Er.S.K.Jain
Er.S.K.Jain
Ductile construction is required for earth quake resistance.
RCC bend on window sill level increase earth quake resistance.
On any height of wall the rcc bend requirement depend on wall height and thickness also with type of structure and earthquake zone.
Sun Oct 25, 2015Post  #2
Vinod
Vinod
Sir, Here we use use 12"x8"x6" solid concrete bricks for the wall, and wall height is around 6.6 feet upto lintel from foundation belt. ie. approx. door height. The wall thickness would be 8" without plastering.
So, is it required/beneficial having additional rcc belt at window still level in  seismic zone III area?
If yes, should I use steel box frame or simple mesh frame using 6mm tmt enough for 4" thick belt?
Sun Oct 25, 2015Post  #3
Go for at least 10 or 12 mm for 4" thick RCC.
Mon Oct 26, 2015Post  #4
Dear Vinod
       In my opinion we need 3 nos connecting lintels/ beams for minimize  danger from earth quack.
1. PLINTH beam or foundation beam.
2. Door level beam/ lintel.
3. Beam at roof level.
1702
1509
1684
3940
Cantilever porch
Last answer on 11/17/2021 10:04:24 AM. by S L Gupta (Civil Engg). Forum started by Capt. Devendra Kumar
1813
I would like to construct building with Earth quake resistence
Last answer on 5/24/2013 12:11:09 PM. by S L Gupta (Civil Engg). Forum started by ananth
3660
Foundation
2206
2180
pile work
6845
Diagonal, Horizontal cracks in RCC walls
Last answer on 10/27/2014 7:21:15 PM. by praveen kumar. Forum started by praveen kumar
4039
2616
Exterior Walls
3272
Roof Concrete Strength
1749
Suggestion on foundation building
Last answer on 7/2/2020 10:05:39 PM. by S L Gupta (Civil Engg). Forum started by Sandeep
2372
i am civil engineerimg student iam in my last yeari am preparing my final year p
Last answer on 10/12/2021 10:36:28 PM. by S L Gupta (Civil Engg). Forum started by sultan
2749
1950
1821
How to level up your WoW game level?
Last answer on 11/23/2021 11:33:21 PM. by Fox. Forum started by weridikka
2840
Choosing the right type foundation and structure for house
Last answer on 9/30/2011 11:52:30 PM. by S L Gupta (Civil Engg). Forum started by Vinod
3312
2312
Earth Filling
Earthing
