Home -> Forums -> Construction -> Brick work -> Construction of AAC block masonary
Sat May 17, 2014Total posts : 2
nitin_patel
nitin_patel
Topic: Construction of AAC block masonary
I request to provide the quantities of Cement and Sand required to complete 1 cum of AAC Block masonary(Block size is 200mmx200mmx600 mm) in 1:6 Cement mortar ratio.
Further,some suppliers provide readymix adhesive alongwith the Blocks ,which is made up of cement,sand and a ppolymer(Factory made),which is comparatively better ,Conventional cement mortar
OR Factory made adhesive.Which would be more economical,as the joint thickness in the traditional blockwork is assummed to be 10mm whereas in case of Ready adhesive it is thin joint work with 2 mm
Mon May 19, 2014Post  #1
Dear Patel
          For 1cubicmeter of concrete block masonry  in cement mortar 1;6 cement required is 0.6 bags and sand5 cft. Use adhesive which is better.
Mon May 19, 2014Post  #2
nitin_patel
nitin_patel
Dear Shri Guptaji,
Thanks for your prompt response.Could you please elaborate as to estimated costing of using conventional cement mortar vis-a-vis adhesive and also the comparative effectiveness of two systems.
2595
Last answer on 9/7/2012 4:18:47 PM. by S L Gupta (Civil Engg). Forum started by narsi vekeriya
3433
1525
5944
Difference between Mortar and Masonary Plastering
Last answer on 10/11/2011 6:39:09 AM. by S L Gupta (Civil Engg). Forum started by sunny420
2749
19139
Solid cement block Vs Bricks
Last answer on 6/10/2012 11:29:35 AM. by jag2. Forum started by jag
1776
what is the size of blocks
Last answer on 3/20/2012 12:26:58 PM. by S L Gupta (Civil Engg). Forum started by Abdul Salam Reki
2069
difference betwen block board and ply board
Last answer on 12/31/2020 2:51:40 AM. by Chetna. Forum started by manisha
1881
Is a apartment block anti-vaastu if it has a pond on its south
Last answer on 3/5/2021 2:56:01 PM. by JAI PRAKASH. Forum started by siddhartha
3495
Robo Sand for Brickwork
2153
2581
Looking for Precast Engineers, Precast Compound Wall and Precast Slabs
Last answer on 5/12/2014 12:54:32 PM. by S L Gupta (Civil Engg). Forum started by nell
7513
Brick Advice Urgent
3046
Which would be a better options for apartments (medium and high rise) Concrete Tanks or Sintex Water tanks
Last answer on 10/20/2010 3:34:11 PM. by . Forum started by savietha
3842
3364
cost saving in construction of house
Last answer on 8/17/2020 2:10:30 AM. by foro. Forum started by raviprakash
3146
Last answer on 8/16/2013 1:12:41 PM. by S L Gupta (Civil Engg). Forum started by K S SHYAM SUNDER
2239
my plot size is 26X35 west facing and right and left side of plot is block. i w
Last answer on 12/13/2013 11:21:27 AM. by S L Gupta (Civil Engg). Forum started by kailash aute
1998
Concrete Hollow Block Masonry
3669
wals
3264
compound wall
21875
3280
Bedroom Wardrobes information
2246
2206
1494
1965
1732
2224
2523
1502
1910
Brick or ACC block
1654
2153
1702
4688
Brick wall on RCC slab
3929
2618
Brick Bonds
Do you know good brick bonds can ensure the strength of a building? Only you need to select appropriate bond for walls..
