Home -> Forums -> Construction -> Brick work -> Cost of Brick Work
Cost of Brick Work
Wed Jun 04, 2014Total posts : 1
Subhajit Kundu
Subhajit Kundu
Topic: Cost of Brick Work
Kindly calculate the cost of Brick Work of a wall admeasuring 100 sft (i.e. 10 ft in height & 10 ft in breadth) in two cases -
a) Thickness of wall is 10 inch   b) Thickness of wall is 5 inch
NOTE : Pl calculate the cost without the Brick cost, i.e. Labour & Cement/Sand work only
Thanks & Regards,
Subhajit Kundu
Wed Jun 04, 2014Post  #1
Dear Kundu
            The cost of brick work in 9'' thick wall is Rs. 9000-00 and cost for 4.5'' thick wall is Rs 4700-00 including the cost of first class bricks.
1844
2521
construction const
35210
4056
2515
Cement
2781
Plaster work
2875
2706
type of brick
3928
5856
2593
JOINERY WORKS
9195
2745
3475
labour charges rates
3925
1918
Water tank
Last answer on 10/1/2014 8:18:00 PM. by JAI PRAKASH. Forum started by karthik
2421
2991
4387
3668
wals
3262
compound wall
21873
3279
Bedroom Wardrobes information
2245
2205
1494
1965
1732
2224
2523
1501
1908
Brick or ACC block
2024
1653
1702
4683
Brick wall on RCC slab
3928
2617
Brick Arches
Specification of Brick
Bricks Quality
Brick Pillar
