Home -> Forums -> Construction -> Cement -> Cost of Cement Plaster
Wed Jun 04, 2014Total posts : 1
Subhajit Kundu
Subhajit Kundu
Topic: Cost of Cement Plaster
Dear Sir
Kindly calculate the cost of Wall Cement Plastering per sq ft with ACC Cement and the Ratio of Sand : Cement is 5 : 1 and the thickness of plastering is 0.75 inch
Pl calculate in case of Ground & First Floor
Thanks & Regards,
SUBHAJIT KUNDU
Wed Jun 04, 2014Post  #1
Dear Kundu
           The cost of cement plaster .75 inch thick with cement sand ratio 1:5 at ground is Rs 15-00 per sft to be done in 2 coats. For first floor is Rs 16-00 per sft.
2695
cement plastering
7006
3992
4212
Selection of cement ..
2205
2523
3843
2438
Gypsum Plaster Vs S/C Plaster
2112
Gypsum plastering
Last answer on 7/3/2020 11:51:16 PM. by Purvi Panchal. Forum started by sanu kumar
2521
construction const
2533
cost of plaster a block wall
Last answer on 2/27/2013 10:58:41 AM. by S L Gupta (Civil Engg). Forum started by kamlesh
3043
2490
Approx.cost of construction from plinth area to completion of plastering for a12
Last answer on 12/23/2013 12:45:58 PM. by S L Gupta (Civil Engg). Forum started by neelam rathi
2017
i want to know about plastering with marble paste and comparison with pop about
Last answer on 8/3/2010 12:02:34 AM. Forum started by sheth sandesh
2415
COSTING AND STRENGTH OF WALL
1748
cost estimation
Last answer on 11/6/2015 12:42:08 AM. by JAI PRAKASH. Forum started by Muhammad.Muqtar Hussain
9158
2503
What will be coast of slab 5" for area of of 450Sq feet. I want material cost l
Last answer on 10/12/2014 9:25:00 PM. by SANJAY DUSANE. Forum started by milind
1510
And how much is labour and material cost to chip old wall and replaster it with
Last answer on 11/8/2017 1:53:56 AM. by S L Gupta (Civil Engg). Forum started by Sheila
1670
Cement requirement
1785
RAW MATERIAL
3443
Type of Cement
2528
RCC Slab -Curing
2327
Materials
23820
Last answer on 2/17/2021 4:49:34 AM. by S L Gupta (Civil Engg). Forum started by vinu
2873
Types of Cement
2515
Cement
2737
Per Square
Last answer on 6/23/2019 11:56:29 PM. by S L Gupta (Civil Engg). Forum started by kiran kumar 3k
1284
1991
Cracks in concrete roof
1242
Last answer on 5/26/2016 12:44:58 PM. Forum started by SUNIL KUMAR
1743
2267
Cement selection
1876
Economical cement brand
Last answer on 2/22/2015 7:02:19 PM. by Bhuwan. Forum started by Bhuwan
1858
Last answer on 4/11/2014 2:04:43 PM. by S L Gupta (Civil Engg). Forum started by shaik khaja nayab rasool
2486
Cement and Grades
Last answer on 6/13/2013 2:45:08 PM. by S L Gupta (Civil Engg). Forum started by MANJUNATH
3043
2437
Past Prices
Last answer on 11/23/2011 10:23:47 AM. by ravi at Dalmia. Forum started by Hemanth
Gypsum
Checklist for Cement Plaster
Specification of ‘Plastering’
How to clean plaster ceiling?
Plastering
Plastering
