Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Cost Comparison Between Brick Wall & Concrete Frame Structure
Thu Oct 20, 2011Total posts : 3
PR Jawahar
PR Jawahar
Topic: Cost Comparison Between Brick Wall & Concrete Frame Structure
Dear Mr. Gupta
I am happy to see your valuable inputs to various questions posted. I am planning to construct an independant house (G+1) total area about 2400sqft. I feel if I adopt framed concrete frame structure with partition walls in single brick (4.5") I would save space as against 9" load bearing brick walls. How would be the cost comparison be approximately. If I adopt framed structure can I use 4.5" or 6" wall for outer side as well apart from partition walls. Kindly respond.
Thu Oct 20, 2011Post  #1
 Dear Jawahar
You can proceed with 4.5'' thick wall in frame structure building. As per your quarry go with 4.5'' wall on out side which are abutting with your neighbourer walls.For detail cost  see link below
Mon Jan 02, 2012Post  #2
varun
varun
Post subject: Concrete frame structure
Hi, i have house which is parking + 4floors.. The builder has build frame structure whereby the roof has been put on Pillar / colum and then exterior walls were put.. My query is 4.5" wall ok for outside ???.. this is a corner plot 3 side open...Please advise...
Thanks,
Varun.
Wed Jan 04, 2012Post  #3
PR Jawahar
PR Jawahar
Post subject: Concrete Frame Structure
Hi Varun,
As already confirmed by Mr. Gupta, I do not see a problem in having wall of any thickness including 4.5" for outside as this is not going to be load bearing wall and reduction in weight by a thinner wall would only aid in minimising the load on the structure. However it is better to check with a structural engineer with available details and the proposed addition..
3432
9195
2024
2991
3470
Cost of concrete walls
3081
2256
2523
2876
2211
1748
3271
Door Frames
Last answer on 10/22/2010 12:50:15 PM. by Mohammed Moin. Forum started by Mohammed Moin
3456
2525
5018
3002
House Estimation Breakdown
1341
1943
Cost of Steel construction
5811
3792
9885
2670
4628
4143
2865
5007
3657
1865
2801
2610
2373
2462
2638
1807
3608
6254
Concrete Mix Ratio
Teak
Teak wood frame
The following tools are recommended for door, windows and ventilator frames:
Cement
Cement Concrete
