Home -> Forums -> Construction -> Brick work -> Cost of Construction of boundary wall for vacant plot
Tue Jul 22, 2014Total posts : 3
Tejpal Singh
Tejpal Singh
Topic: Cost of Construction of boundary wall for vacant plot
I have a vacant plot in mohali. I need to construct a boundary wall. I have these queries in my mind to take the decision:
- Should a brick wall be constructed ?
- What should be the minimum height of the wall ?
- What should be the cost of constructing the brick wall ?
I would appreciate if I get the answers to these queries.
Thanks,
Tejpal
Tue Jul 22, 2014Post  #1
The brick wall is ok.
keep the height as per your requirement.
The cost would be around 80-100/Sq.Ft. for a 9' wall.
Wed Jul 23, 2014Post  #2
Tejpal Singh
Tejpal Singh
Thanks for the info Jai Prakash.
Wed Jul 23, 2014Post  #3
MANJUNATH
MANJUNATH
Post subject: Cost of Construction of boundary wall for vacant...
The cost of constructing  boundary wall ( Compound)  is measured either in running foot or in cubic foot and not in Square foot. Pl clarify.  Secondly, it also requires proper foundation.  It appx costed me Rs.500/- per running foot for 5 feet high boundary wall of   9 inch thickness, during 2003.
3083
2863
Need help regarding boundary wall construction
Last answer on 8/27/2013 11:59:55 AM. by S L Gupta (Civil Engg). Forum started by sonu.211
2176
2523
2559
3543
Contruction Tool
16629
COST ESTIMATE OF BOUNDARY WALL PER FOOT
Last answer on 7/4/2020 3:35:51 AM. by S L Gupta (Civil Engg). Forum started by sira
5347
estimate for construction of boundary wall
Last answer on 2/27/2015 3:49:38 AM. by JAI PRAKASH. Forum started by vanish
2564
Last answer on 3/2/2015 12:09:44 PM. by seema tyagi. Forum started by Alok
7412
750 Sqft Construction
2025
What will may be full construction estimate cost plot size of 25*45, pl send me
Last answer on 7/4/2020 3:43:22 AM. by S L Gupta (Civil Engg). Forum started by mahendra kumar dutta
1774
in chennai i had to miss a plot of 1gd saying there was vacant space in west in
Last answer on 8/11/2011 10:14:48 PM. Forum started by D.Ramachandran
3460
I want do construct a home, plot size (20x50)feet.What is the construction cost
Last answer on 3/25/2016 3:05:19 PM. by S L Gupta (Civil Engg). Forum started by Santosh Singh Bhadoria
6100
What is construction cost
2481
Basement Wall in my plot
Last answer on 7/28/2012 6:30:53 PM. by Naveen Reddy. Forum started by Naveen Reddy
5275
Looking for good designs and estimation costs for 1000 sq yards marriage hall
Last answer on 6/27/2021 2:44:52 AM. by S L Gupta (Civil Engg). Forum started by faiz
7024
Cost of stilt parking
Last answer on 5/19/2014 10:08:36 PM. by awdhesh. Forum started by awdhesh
4808
3669
wals
3264
compound wall
21879
3280
Bedroom Wardrobes information
2246
2206
1495
1965
1732
2225
2523
1502
1910
Brick or ACC block
1654
2153
1702
4688
Brick wall on RCC slab
3929
2618
Canvas
Canvas Wall Art
