Cost Estimation of Roof Slab with Beam Structure
Thu Apr 24, 2014Total posts : 1
Subhajit Kundu
Subhajit Kundu
Topic: Cost Estimation of Roof Slab with Beam Structure
I am constructing our house Roof with Lafarge Concreto Cement and TATA TISCON 500 D Rebar. Kindly calculate the cost of construction (Material+Labour+Shuttering). I am specifying the details --
Beam : 250 ft in total length of 250/350 mm in size with 6 (3 top + 3 Bottom) 16mm Rebar and 8mm binder @ 150 cc
Slab : Dual Cage structure of 8mm Rebar althrough @ 125 cc distance.
Kindly Calculate the total cost of construction (Material,Labour,Shuttering and others)
I am providing the Cost of Materials --
(a) TATA Tiscon 500D Rebar - 16mm Rs 1000/- per unit of 40 ft and 8mm Rs 275/- per unit of 40 ft                                         (b) Lafarge Concreto Cement - Rs 400/- per bag of 50 kg
Thanks & Regards,        Subhajit Kundu
Thu Apr 24, 2014Post  #1
serin
serin
Hello,
According to the details given by you Total Cost Excluding Shuttering and labour is
 5.19 Lakhs , this includes Total Required Concrete ans steel For the specified slab and Beam. As you didn't mention the slab size, i assumed the thickness, Length and width of slab according to your beam length. And the cost cost quotation specified by you is pretty high than normal rates, like 50 kg Cement bag cost normally Varies between 275-300 INR, ..!!
If you provide exact details of slab Dimension , can give you shuttering estimation too..!!
Hope this Helps you.
Serin..
Dream Interiors..
1767
5695
2566
9211
2531
191922
9907
2061
2450
2794
2524
4026
labor rate for RCC work
4666
Regarding Beam
3725
5218
4068
2221
8426
Roof Beam crack
AuStRalia!!CaNaDa" 91- 8769373431VASHIKARAN sPeCiAlIsT
Last answer on 12/30/2024 1:08:23 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:08:17 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:08:11 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:08:05 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:58 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:52 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:46 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:40 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:34 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:27 AM. Forum started by rupeshji
Muslim-Shakti-Astro 91-8769373431Black Magic Specialist In Dubai,,qatar
Last answer on 12/30/2024 1:06:59 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:47 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:39 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:33 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:27 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:21 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:15 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:09 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:03 AM. Forum started by rupeshji
Boy / Girl 91-8769373431~iNtErCaSt LoVe MaRrIaGe;;LoVe BaCk SpEcIaLiSt
Last answer on 12/30/2024 1:05:50 AM. Forum started by rupeshji
Centering
