Home -> Forums -> Construction -> Pillar Work -> Cost of construction of RCC Piller with Foundation
Mon Apr 21, 2014Total posts : 1
Subhajit Kundu
Subhajit Kundu
Topic: Cost of construction of RCC Piller with Foundation
I am constructing our house with TATA Tiscon 5ooD Rebar and ACC F2R Cement. Kindly advise the Construction Cost (Material+Labour) for each Piller (with Foundation). I am specifying the details
Foundation : 1200 mm / 1200 mm/ 1500 mm (dimension), Cage (1200/1200 mm) made of 12mm TATA Tiscon 500D rebar @125 cc, Cement used ACC F2R Cement and Grade of Concrete M20.
Piller : 11 ft in height, 4 no 16 mm and 2 No 12 mm rebar with 8mm binder @150 cc has been used.
Kindly advise the Cost of construction (Material+Labour & others)
Subhajit Kundu
Tue Apr 22, 2014Post  #1
Dear Kundu
        The cost can be calculated with the size of footing and columns.
The cost per cft of RCC in footing including labor material and steel = 250-00 to 270-00
The cost per cft of RCC in  column including labor material and steel = 320-00 to 350-00.
Pillar Work-Construction Questions (39)
3882
stone foundation
1064
1586
i want to knw cost about making a piller height 4 feet and 8*8
Last answer on 6/9/2021 8:12:51 AM. by ]Greis. Forum started by RUPESH RATHORE
Foundation + RCC SLAB+ Pillers 30*40 site for G+2
Last answer on 3/30/2014 6:12:34 PM. Forum started by vikas
1878
column
8651
4064
RCC consultant fee
Last answer on 12/4/2021 9:54:41 PM. by S L Gupta (Civil Engg). Forum started by milind jadhav
5856
2975
2521
construction const
2032
4647
1456
Dear Sir,We are planing to building faction hall at our place. function hall she
Last answer on 8/8/2017 12:11:18 PM. by S L Gupta (Civil Engg). Forum started by Sha alam
1509
6529
4949
3879
32559
Cost of RCC Pillar
6436
position of pillars
1878
column
1780
First floor plan suggestions
2523
Pillar cost
4036
42124
12461
First floor construction
2501
2503
Length of cantilever beam
2537
RCC column (pillar)
9225
pillar size in distacce
9195
2823
2694
1993
2207
3159
Laping length requirement
Designing
Designing a Foundation
