Dear Mr.S.L Gupta, I am currently constructing a house. Marble has b
Thu May 01, 2014Total posts : 2
Anurag
Anurag
Topic: Dear Mr.S.L Gupta, I am currently constructing a house. Marble has b
Dear Mr.S.L Gupta, I am currently constructing a house. Marble has been laid recently and False filing work is going on. My main query is After this job how should I proceed ? As granite staircase work, facade, bathrooms and kitchen tile work, gates grills and wood work, wall putty, electrical wiring are still pending. Please do answer my query.I look forward to hear from you soon.Thanks,Anurag.
Mon May 05, 2014Post  #1
Dear Anurag
         First of all you should do electric wiring so that if any problem come can be rectified at once before the finishing items.
After that flooring, wood work, grill work taken in hand.
Wall putty and painting is last items.
Mon May 05, 2014Post  #2
PR Jawahar
PR Jawahar
Post subject: Protecting the marble floor
Anurag,
I guess your concern is to protect the marble floor as well against possible damages due to ladder, scaffold etc. Usually it is better too apply a layer of plaster of paris over the marble floor so that it protects against any damages. Cover the sharp objects such as ladder feet etc with a rubber sheet or thick cloth to protect against damage to the floor.
The plaster of paris could be later removed by easily tapping off and also a mild polish after this.
With regard to the sequence of work I agree with Mr. Gupta's suggestions.
CURING TIME FOR RCC ROOF
6442
Column placement for house
2474
16809
Construction Cost per square ft in Gurgaon
Last answer on 2/22/2013 11:53:26 AM. by S L Gupta (Civil Engg). Forum started by Pawan Rao
65239
1487
Hello Architects, currently i am having G 1 house with 1250sqf area with 12 colu
Last answer on 3/15/2016 1:20:57 PM. by S L Gupta (Civil Engg). Forum started by babu
3216
Dear Gupta sir,My house plan 30*40 wht's the cost of flooring, i plan for tiles,
Last answer on 7/3/2020 11:39:27 PM. by S L Gupta (Civil Engg). Forum started by shan
2310
i am having a south facing house before constructing this house,our econimic con
Last answer on 4/9/2010 3:20:54 PM. by amol. Forum started by sudeep
2090
dear sir I want to construct a house according Vastu in 20
Last answer on 12/27/2014 7:24:03 PM. by Navneet Jharia. Forum started by bsp
2569
2317
Hi my Name is Riyaj khan i am Marble flooring liver incharge for indian Marble,
Last answer on 7/3/2020 11:34:52 PM. by JAI PRAKASH. Forum started by RIYAJ KHAN
1978
Removal of wall
1515
I am constructing a house in Dharamsala ( place having second highest rain falll
Last answer on 12/21/2015 1:41:44 PM. by Bhupinder Kumar. Forum started by Bhupinder Kumar
2319
Water proofing method
3510
1340
1529
I am having 30x40 plot facing south and i want to construct house with east faci
Last answer on 7/3/2020 11:36:54 PM. by S L Gupta (Civil Engg). Forum started by DINESH P
2842
Water seepage from RCC slab
3434
18
Italian
Italian Marble Flooring
Specifications
MARBLE STONE
Marble shall be hard ,sound , dence, and homogeneous in nature with crystal in texture as far as possible.
White
White Marble
Nowadays marble become to be a favorite material for kitchen countertops, sink tops, floors, and wall tiles. White ma..
Environment
Environment Friendly Houses
