Dear Shri.Guptaji,My ground floor house has been constructed on pillars with bea
Wed Jul 23, 2014Total posts : 1
MANJUNATH
MANJUNATH
Topic: Dear Shri.Guptaji,My ground floor house has been constructed on pillars with bea
Dear Shri.Guptaji,My ground floor house has been constructed on pillars with beams. First floor which I am planning will be same as ground floor and walls for it will be exactlyon the walls of the ground floor. However, I also want to construct 2nd floor, smaller than the 1st floor and position of walls will not be same as ground floor and 1st floor. Is this possible ? If so, does it require major changes in the structural drawings - beams and pillars?. Pl suggest. Offcourse, I shall take help of architect.
Tue Jul 29, 2014Post  #1
Dear Manjunath
          First of all I suggest that take advice and drawing from any structural or civil engineer.
At the time of laying first floor roof you should give beam under the newly proposed walls which are to be constructed at Second floor.
3238
1340
5812
2475
2540
Last answer on 7/4/2020 2:31:17 AM. by S L Gupta (Civil Engg). Forum started by ramaiyacp
3230
2950
Number and position of pillars
Last answer on 7/3/2020 10:41:58 PM. by Ananda. Forum started by Ananda
2695
3510
2352
Check the load
Last answer on 11/17/2013 12:35:51 AM. by Dilip. Forum started by Dilip
5124
5086
1997
I have a house constructed in 1991 with 15 feet foundation. (It is a pillar foun
Last answer on 1/16/2015 2:09:58 AM. by JAI PRAKASH. Forum started by Manoj
3129
Plinth beam at ground level
1540
dear sir,i saw website can u help me to design my house plan..east faceing with
Last answer on 8/3/2016 12:24:24 PM. by Beenu Phogat. Forum started by anil
12462
First floor construction
24
28
Brick Pillar
Preliminary
Pool Pumps
Painting
