Home -> Forums -> Construction -> Layout and House Plans -> Design of water tank on terrace?
Mon Jun 20, 2011Total posts : 2
tiwari_p_k
tiwari_p_k
Topic: Design of water tank on terrace?
I am just done with basic construction of 1 floor bunglow row house. Now I would like to do some construction work for water storage on top floor slab. What will be best for it? Concrete tank or syntax tank? I am planning to go for syntax tank, so just would like to know any good deign for it? Like 4 pillare on terrace with small concrete slab covering it and then syntax tank inside it? But looking for any other good and feasible design options from experts. Please suggest.
many thanks in advance.
regards
pras
Wed Jun 29, 2011Post  #1
subhakankhi
subhakankhi
Post subject: OHWT
Hello
In the above mentioned project, I feel SINTEX is the best option. The only problem with it is that, water get heated up quite easily. If site condition permits, I prefer to construction a slab on pillar at 2' to 3' above roof, add 5" wall to three sides, except the east site, to a height equal to height of the tank. Make sure that there is space all around the tank for cleaning.
Concrete, is heavy on the structure, moreso it is very difficult to manage the water leakage.
SINTEX is the dry solution.
Subhakankhi
(Architect)
Tue Oct 18, 2011Post  #2
Ramachandran
Ramachandran
Post subject: Water tank
Hello,
The present building is Bungalow house consisting of ground plus 1 floor.   Over and above the 1st floor on the terrace floor  there are two existing water tanks, out of  which from one water tank, water is leaking and hence seepage of water in interior walls.   What will be best option whether to repair the same or go for buying a syntex water tank and keep the same above this water tank? Since there is another tank which takes care of most of the water requirements and this one is used for only washing, bathing inside the house, will it be  syntex tank having capacity of 500 litres  is installed above the existing tank. Please suggest.
Many thanks in advance
With kind regards
Ramachandran
1856
5070
1811
1743
1943
2194
2905
Terrace water proofing
2386
water tank
2497
3132
7246
2 lakh litre water tank
6284
Water Tank Quality
1892
water tank motor capacity
2393
2775
roofing on open terrace
2245
2335
Overhead water tank design
Last answer on 10/26/2016 12:48:05 PM. by S L Gupta (Civil Engg). Forum started by Rakesh
2306
2697
2931
2194
2194
2809
4531
1898
2292
2278
2779
3474
2366
1980
2255
3604
2099
2802
1558
2128
Roof Garden
Vastu for Water Tank
Preventive
Reasons of dampness
General
60
60 Tips to Save Water
Porch
Porch Designs
