Home -> Forums -> Construction -> Layout and House Plans -> First Floor layout should be same as Ground floor?
Wed Jan 12, 2011Total posts : 2
Geetika
Geetika
Topic: First Floor layout should be same as Ground floor?
We are making two storied house.
 The First Floor Layout Plan DO NOT match Ground Floor plan and builder will not keep extra beams to carry the load of first floor walls. Internal wall weight will be on GF roof slab.
Will this cause problem to us when we want to go for third storey in near future?
Sat Jan 15, 2011Post  #1
Dear Geetika
                when you know that your builder is not making the necessary beams for taking the load of wall of the first floor than it is up to you to ask builder for doing the same. If that will not include in the contract agreement than now pay some extra and do the needfully which will be usefully for further construction.
                  The other option is that you can lay the fresh beam under the new construction of wall where required in the building.
Sun Jan 16, 2011Post  #2
Geetika
Geetika
Thank you for your response.
I asked the builder to provide extra beams. However, it told then the beams will come inside the GF rooms which will not look good. So we are thinking to make FF plan same like GF plan to avoid these issues.
Geetika
Layout and House Plans-Construction Questions (40)
9979
3246
1779
2072
2492
1655
Design Layout for Shops and Flats
Last answer on 5/10/2016 11:43:26 AM. by S L Gupta (Civil Engg). Forum started by Amir Rehman
1932
Last answer on 11/15/2016 2:10:38 AM. Forum started by K Srinivasan
2395
1423
want to see ground and first floor plan of it
Last answer on 6/28/2016 2:34:13 PM. by S L Gupta (Civil Engg). Forum started by s k tiwari
3683
24feetby 81feet house plan ground floor ,dabal parking, one shop.
Last answer on 7/3/2020 11:24:29 PM. by S L Gupta (Civil Engg). Forum started by Pramod kumar
5039
pls sent a suitable front elevation for 20x60 ground and first floor building
Last answer on 1/22/2022 12:11:35 AM. by bablu suthar. Forum started by naga
2331
5132
2387
Spiral staircase from first ground floor to first floor
Last answer on 3/4/2015 12:37:11 PM. by satish. Forum started by satish
1611
How much Marole required
3498
I AM LOOKING FOR A FLOOR PLAN FOR 36X72 PLOT WITH 3 BEDROOMS AT GROUND FLOOR .
Last answer on 2/26/2012 2:32:46 PM. by aman. Forum started by INDER PAL
2749
3138
1551
dear sir,i saw website can u help me to design my house plan..east faceing with
Last answer on 8/3/2016 12:24:24 PM. by Beenu Phogat. Forum started by anil
2697
2930
2194
2194
2809
4531
1898
2292
2278
2779
3474
2364
1980
2254
3602
2099
2801
1558
2128
Preliminary
Terrazzo
Pool Pumps
Tips for Oil Bound Distemper
