Home -> Forums -> Construction -> Brick work -> Fixing 8" pvc pipe through bathroom wall for fitting exhost fan
Sun Jan 15, 2017Total posts : 1
Topic: Fixing 8" pvc pipe through bathroom wall for fitting exhost fan
Is fixing a pvc pipe of 8" dia through bathroom wall enough for fitting an  exhost fan? Whether there will be problems in finding exhost fans with rounded shape back for a direct fit to 8" pipe? or Should I provide 8" square hole?
Mon Jan 16, 2017Post  #1
Dear Vinu,
        Use ply for making size hole according to requirement.
2945
SIR, I AM CONSRUTING MY HOUSE IN PATIALA AND CONFUSE THAT WHICH PIPE GI , PVC ,U
Last answer on 1/18/2012 8:33:27 AM. by ravi at Dalmia. Forum started by HARISH SAHNI
2345
what is the diffrence between u-pvc ans pvc pipes
Last answer on 7/31/2014 7:59:31 PM. by GUNA. Forum started by SANJAY DUSANE
2588
modern lighting
Last answer on 3/19/2015 12:34:01 AM. by JAI PRAKASH. Forum started by electricalproducts
2243
ceiling fan
Last answer on 12/1/2011 4:29:33 PM. by Alexander. Forum started by sunil
1829
2937
1991
PLUMBING
1757
Dear Sir Constructing 72x43 East facing house.Pl guide me for water supply pipe
Last answer on 9/30/2015 8:59:54 PM. by JAI PRAKASH. Forum started by Sudhir Pathak
sewage pipes
9178
3300
5099
Stop Rats from entering In house via Drain pipe
Last answer on 6/10/2011 11:47:24 PM. by P. Panchal. Forum started by P. Panchal
2698
PVC WALL PANELS ,....PL I WANT THE COST TO COVER 200 SQ FT IN LIVING ROOM.
Last answer on 6/7/2015 1:35:53 AM. by JAI PRAKASH. Forum started by sanjay
2882
Last answer on 9/30/2020 7:45:37 AM. by Vijay Mishra. Forum started by SCK
2170
Last answer on 3/5/2016 9:14:04 PM. by JAI PRAKASH. Forum started by gulam yazdani
1795
PVC Walls & Ceilings
Last answer on 12/24/2015 4:20:28 AM. by JAI PRAKASH. Forum started by sushantsah
1889
kitchen Cabinets
Last answer on 12/17/2015 2:51:28 PM. by JAI PRAKASH. Forum started by ARVIND GOYAL
2240
Good and latest Bath Room Wall Mixer
Last answer on 6/10/2013 6:00:38 PM. by elinahenry. Forum started by raghuam
2336
3672
wals
3267
compound wall
21893
3283
Bedroom Wardrobes information
2247
2211
1969
1733
2228
2528
1505
1913
Brick or ACC block
1657
2153
1707
4708
Brick wall on RCC slab
3934
2623
Bathroom Ventilation
Bathroom ventilation is very essential for good health and contents of the house. It is applied to get rid of heat, hu..
Bathroom Accessories Part-4
Ceiling
Ceiling Fans
General
Vinyl
Vinyl Flooring
Energy
Energy Saving Fans
Everyday rising energy demands reminds us to explore new energy saving devices. Energy saving ceiling fans is such a d..
Bathroom Pictures
