Fri Feb 17, 2017
pramod
Topic: Foundation type of Land which is 5 Feet down to Road Level
Hello People,
Am planning to construct new home and plot size of 33 X 45 Size.
But the plot is down to 5 feet to from Road level. So i would be needed to my House level 1-2 Feet above the road level which will 6-7 from the ground level.
Which type of basement plan is good for this? Pillars till the road level and plinth beam on the ground level is fine or do i need to have pillars connected through foundation at ground level? Please help.
Fri Feb 17, 2017
2509
Help regaring foundation
Last answer on 4/16/2014 3:46:11 PM. by
SANKARDAS BANERJEE
vaisakh
2205
Last answer on 5/2/2017 5:25:23 PM. by
pramod
2072
Last answer on 1/8/2018 11:06:10 PM. by
ravikumar
2090
Foundation
Last answer on 2/9/2021 1:27:59 AM. by
Pooja
3317
My plot is 5 feet below the road level. Will fill it up with sand after the foun
Last answer on 4/25/2018 1:12:52 AM. by
RAJAT BANGA
1603
can v down the floor in hall hall size 20* 20 down area 10*15down depth 1 feet h
Last answer on 1/2/2021 5:22:31 AM. by
durai
2957
Need suggestions
Last answer on 2/28/2014 8:14:45 PM. by
viju
viju
3660
Foundation
Rohit Sharma
Last answer on 8/11/2017 2:16:01 AM. by
HOME
Vijay Yadav
1707
sir,i want to a map 40*40 land it has both side road
Last answer on 6/5/2017 12:47:54 PM. by
Saurav anand
SONU RAJ
12251
Last answer on 1/18/2013 3:22:15 PM. by
gnyoganarasimhan
selva
5346
estimate for construction of boundary wall
Last answer on 2/27/2015 3:49:38 AM. by
vanish
1748
Suggestion on foundation building
Last answer on 7/2/2020 10:05:39 PM. by
Sandeep
2151
house plan for 39 feet road side and 32 feet depth for noth facing
Last answer on 1/2/2015 11:13:55 AM. by
ravi kiran
1789
Foundation
Last answer on 7/3/2020 9:42:13 PM. by
Gaurav Wadhwa
2501
Last answer on 10/20/2016 6:00:32 PM. by
Naveen
1592
Hi, My Name is mustkeem I m from Paonta Sahib, Sirmour HP, I need a Plan. My po
Last answer on 1/10/2016 9:05:18 PM. by
Mustkeem
2821
building a house
nashir
1699
How should be footing net for column adjacent to existing wall
Last answer on 6/3/2017 3:04:50 PM. by
Surinder Singh
Designing a Foundation
