Hi, Having a plot of 30x50 facing road 53 degrees from north, so assuming northe
Thu Feb 20, 2014Total posts : 4
satishb
satishb
Topic: Hi, Having a plot of 30x50 facing road 53 degrees from north, so assuming northe
Hi, Having a plot of 30x50 facing road 53 degrees from north, so assuming northeast direction of the plot, Planning to build a house with duplex first and second floor for our use as our budget is around 30-35L.In future want to plan to build ground for 2/1bhk 2 car parking and 2bhk at top floor.My query is that is this option feasible considering the construction structural dynamics, as we need two stair case(1 internal,1external), budget,time, multi-contractor so on. Any suggestion will be appreciated. Regards, Satish B
Fri Feb 21, 2014Post  #1
Dear Satish
Mon Feb 24, 2014Post  #2
Shanthakumar
Shanthakumar
Dear Satish,
Your option is feasible enough but it won't fit your budget!!! My suggestion is to reconsider your requirement to bring down cost. For example, Any way it is duplex, we can have single staircase as well. Two staircases in single floor occupies more space and it increases the material cost as well.
Shanthakumar.
Architect.
Mon Feb 24, 2014Post  #3
Architect Sanathkumar is right
Wed Mar 12, 2014Post  #4
satishb
satishb
Thanks Shanthakumar and Purvi for suggestion, Sorry for delayed response. Firstly budget is the main constraint, will rework on the requirements as suggested. One quick question If i make Ground floor stilt will it reduce cost/Fit in the budget?
I have 30*53 West facing 40 ft road house duble store map as per vastu
Last answer on 2/4/2019 11:12:36 PM. by S L Gupta (Civil Engg). Forum started by Manojkumarmeena
3157
Construction House plan require for G+1 for plot size of 31* 53
Last answer on 11/29/2016 6:16:06 PM. Forum started by baji
2742
Last answer on 8/11/2017 2:15:35 AM. by HOME. Forum started by parveen sharma
1545
North face 30x50 vastu plan 1/2/3 floors
Last answer on 9/16/2015 1:09:03 AM. by JAI PRAKASH. Forum started by gopal mahajan
3306
3608
i need plan for north facing plot 23 x 47 road facing 47
Last answer on 3/4/2012 8:49:29 PM. Forum started by solairaja
1916
Hi, What facing plot is good to build house North east facing plot or East facin
Last answer on 3/5/2016 10:37:39 PM. by JAI PRAKASH. Forum started by Sri
1606
dear sir , i have a plot at the end of the road. its facing north towards road
Last answer on 9/24/2011 7:48:59 PM. by Gunjan Utraja. Forum started by PANKAJ NAGAR
4520
2675
plot having west side &south side road
Last answer on 8/21/2014 2:42:37 PM. by Dilavarsinh Vaghela. Forum started by rahul kulkarni
2043
30×41 north facing plot 2 side road north and south. i need 3 room with puja gha
Last answer on 11/1/2021 5:47:56 AM. by S L Gupta (Civil Engg). Forum started by sumit
1175
Hi sir my plot size 20*60south facing road naku east facing lo entrance undeala
Last answer on 8/22/2018 2:23:59 AM. by S L Gupta (Civil Engg). Forum started by THOGATA Mallikarjuna
5961
Last answer on 11/14/2016 11:10:29 AM. by Ashok. Forum started by gmaghesh
3078
North Facing 26 X 58 FEET PLOT ANY ONE HAVING DRAWING PLEASE POST... For Duplex
Last answer on 1/21/2021 1:13:36 AM. by HOME. Forum started by gangula
3474
2267
I need 30x50 feet east facing ground floor house plan with 3 bedrooms
Last answer on 7/11/2016 1:48:57 PM. by Amrit Bhagat. Forum started by ananddv3
2151
house plan for 39 feet road side and 32 feet depth for noth facing
Last answer on 1/2/2015 11:13:55 AM. by seema tyagi. Forum started by ravi kiran
2253
Compact
Compact Hi-Tech Kitchen
Basic
Basic home security tips
Pooja
Pooja Room Vastu
