Sun Aug 12, 2012 | Total posts : 5 |
| Topic: I HAVE A BUILDING G 2 SIZE 26'X40' AND NOW I PURCHASES ON A FIRST FLOOR CHHAT SI
I HAVE A BUILDING G 2 SIZE 26'X40' AND NOW I PURCHASES ON A FIRST FLOOR CHHAT SIZE 36'X20'IN MY NORTH 5'FEET EXTRA BOTH SIDE IN EAST AND WEST |
Mon Aug 13, 2012 | Post #1 | Gunjan Utraja
Join date: Dec 2007 | Post subject: Confirm the strength of the existing structure.
Please confirm the strength of the existing structure by hiring a structural engineer.
He will check whether the building is strong enough to hold more construction.
Also, look at the following links to view the plans:
From these link you can have ideas about the planning. | |
Thu Aug 16, 2012 | Post #2 | MURARI GARG
basically my problem is some what diffrent, i have 26' x 40' g+2 house, this house is south facing and recently i had purchased the roof behind my house its size is 36' x 20'. This roof is 6" upper then my existing floor of my existing house or we can say this roof is 6" upper then the roof of my ground floor. i am also attaching the plan map of it, please advice me is there any problem in attaching it with my existing house and to do construction on it.
Sun Aug 19, 2012 | Post #3 | Ar. Manoj Ralen
Join date: Feb 2008 | Dear Mr. Garg, Ideally if you combine both the floors then your architect would have more options of planning the space. Joining should not be a problem as once you construct rooms on top of your existing roof then you would need to do flooring also and 6 inches can be covered in that. Your structure should be strong enough to hold construction over your existing building so ask a civil or structure engineer to visit your site and confirm this. Other things would be easy to take care of.
Regards | |
Sun Aug 19, 2012 | Post #4 | P. Panchal
Join date: Apr 2011 | I don't think there is any problem if rear roof is at upper level. you can go ahead.
Thu Aug 23, 2012 | Post #5 | Ravi
Mr Garg, Please confirm the strength of the roof, if it is strong enough then there is no problem in joining your house to the roof. Secondly, for interior designing also it will not create any problem. For more queries, please feel free to contact me. Regards Ravi | |
Articles that might interest you! | | Innovative designs for Small kitchen Small kitchen seems difficult to manage. In fact they are less cluttered. But it all depends on planning a small space.. | | Buying tips for Brick Blast You need to know these tips to buy Brick Blast for the construction of your home or commercial building. | | Buying tips for Cement A good home construction starts with good raw material procurement. Let's start with cement | | Purchasing Guidelines for Fine Aggregate/ Coarse Sand There should be no silt contents in Coarse Sand as the suppliers try to charge much amount by supplying the material o.. | | Purchasing Guidelines for Cement Manufacturing date, grade and type play vital role in purchasing right cement and there should be no lumps in it. | | Tips to remember while purchasing a garden bench.
| | Aluminum door frame standard size There are various options of sizes in aluminum doors available in market. Choose the right one according to your purpo.. | | Orientation of Building To get maximum ventilation and natural light in your house, make sure the building is properly oriented. Orientation o.. | | Tips for Cement Paint Cement paint perks up exterior surfaces and maintains good looks of a building for many years. It offers matt finish o.. | | Building New Home V/S Buying Builder Flat Buying a builder’s flat may be costlier for you rather than building a new home. But if you plan to make your own, you.. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
