I am constructing a house in Dharamsala ( place having second highest rain falll
Wed Dec 16, 2015Total posts : 4
Bhupinder Kumar
Bhupinder Kumar
Topic: I am constructing a house in Dharamsala ( place having second highest rain falll
I am constructing a house in Dharamsala ( place having second highest rain falll in India). My question is: Does plinth beam work as a DPC ? or I have go for separate DPC barrier?
Thu Dec 17, 2015Post  #1
Pooja
Pooja
Plinth beam act as DPC but it is always better to have bitumen coating over top surface of plinth beam
Thu Dec 17, 2015Post  #2
Dear Bhupinder Kumar
              Yes it is right that plinth beam with bitumen coating is better option that of DPC. Care should be taken some mason not laid floor at that level and put masonry on plinth beam and raise the floor level, check the level of plinth beam and floor is same.
Thu Dec 17, 2015Post  #3
Correct.
Mon Dec 21, 2015Post  #4
Bhupinder Kumar
Bhupinder Kumar
Thanks for your valauble suggestions
2525
Last answer on 7/4/2020 2:31:17 AM. by S L Gupta (Civil Engg). Forum started by ramaiyacp
2633
2294
i am having a south facing house before constructing this house,our econimic con
Last answer on 4/9/2010 3:20:54 PM. by amol. Forum started by sudeep
3270
I have constructed a small house (120 Sq yards) having two bedrooms in south eas
Last answer on 10/12/2012 8:06:32 PM. by krishna. Forum started by Anuj Anand
5735
2719
Last answer on 8/11/2017 2:15:35 AM. by HOME. Forum started by parveen sharma
1516
I am having 30x40 plot facing south and i want to construct house with east faci
Last answer on 7/3/2020 11:36:54 PM. by S L Gupta (Civil Engg). Forum started by DINESH P
1322
1766
iam having 25 x30 dimension site i want to construct duplex house plz provide me
Last answer on 8/16/2016 1:42:26 PM. by Beenu Phogat. Forum started by munegowda
1597
I have open site of 30'*50' size. I want to construct an house having sitout din
Last answer on 4/4/2018 1:22:54 AM. by S L Gupta (Civil Engg). Forum started by appasaheb
6359
Column placement for house
2183
Advise on Column Schedule
Last answer on 2/10/2014 1:49:50 PM. by abhishek0990. Forum started by Ajay Kostha
3412
5146
2977
Basement Interior Design
Last answer on 11/26/2010 2:58:05 PM. by S.C.Chawla. Forum started by Boby
2210
New Construction
2291
1999
front elevation design
Last answer on 4/18/2016 11:55:19 AM. by S L Gupta (Civil Engg). Forum started by PRADEEP KUMAR
201
64
23
21
22
22
24
21
21
23
21
21
17
25
18
23
23
10 things to check before the rain hit your home!
Rain is fun but the fun may not last if your home fails to protect itself and its occupants from the elements. This wr..
Rain
Rain Water Harvesting
Tips for Oil Bound Distemper
