Home -> Forums -> Construction -> Vastu Shastra -> I want to build home and dental clinic in 30by 45 two sides open north and West
Mon Feb 17, 2014Total posts : 3
Rakesh
Rakesh
Topic: I want to build home and dental clinic in 30by 45 two sides open north and West
I want to build home and dental clinic in 30by 45 two sides open north and West plot. in ground floor West said open clinic in 18 by40
Mon Feb 17, 2014Post  #1
Dear Rakesh
Mon Feb 24, 2014Post  #2
Shanthakumar
Shanthakumar
Dear Rakesh,
It is very much possible to have a house and dental clinic in your plot. However as far as design concern you shouldn't consider this as same as other house design. Key term here is the "customization"...Spend more time on customize each space based on your need before starting the construction process.
Shanthakumar.
Architect.
Mon Feb 24, 2014Post  #3
Better if You contact a local architect or engineer.
Vastu Shastra-Construction Questions (39)
3010
Last answer on 2/21/2022 6:45:23 AM. by S L Gupta (Civil Engg). Forum started by parkash
2529
Kindly tell vastu tips for west facing plot for construction of dental clinic
Last answer on 10/1/2021 5:05:33 AM. by JesseMWoodley. Forum started by Adarsh
10137
i have a dental clinic facing west..
Last answer on 9/25/2012 10:53:10 AM. by Amit Hasija. Forum started by monalsingh
3369
plz tell me ideal position of dental chair n patient position in east facing den
Last answer on 7/3/2020 11:54:24 PM. Forum started by dr mona
2249
Last answer on 7/2/2014 11:22:25 PM. by marimuthu.p. Forum started by Rakesh
2717
Last answer on 8/11/2017 2:15:35 AM. by HOME. Forum started by parveen sharma
3185
for a flat
Last answer on 10/13/2010 5:18:56 PM. by lokareddy. Forum started by shrawan
3644
3757
Vastu features for a dental clinic facing south ....
Last answer on 7/3/2020 11:24:40 PM. by S L Gupta (Civil Engg). Forum started by AKP
3235
my plot east 36 north 50. north and west 2 side road, i want 4 side open pls sug
Last answer on 11/3/2014 5:15:20 PM. by Ashok. Forum started by ravi
2510
sir, i have a east facing home, which front side two shop and ceter main door an
Last answer on 1/6/2013 6:04:55 PM. by sapnajain. Forum started by sapnajain
3649
exact position of main entrance of clinic
Last answer on 8/1/2018 11:05:25 PM. by S L Gupta (Civil Engg). Forum started by saorabh
1382
i want built a home size 25/57 two side road
Last answer on 9/16/2017 12:37:24 AM. by S L Gupta (Civil Engg). Forum started by Ajay pratap
3025
vastu home map north facing plot 13 by 45
Last answer on 5/30/2015 8:25:07 PM. by JAI PRAKASH. Forum started by nitin
1731
My plot in city paonta sahib HP 17302939*45 ft I want's to a good vastu shastra
Last answer on 10/14/2021 8:51:31 AM. by S L Gupta (Civil Engg). Forum started by Anil Kumar
3936
Last answer on 10/11/2020 7:21:30 AM. by S L Gupta (Civil Engg). Forum started by maruthi prasad
7616
Can you give proper plan for dental clinic as per vastu shastra.
Last answer on 5/11/2011 1:33:04 PM. by Gunjan Utraja. Forum started by Dr. Pawar Vilas S.
2603
My homes is opened at north direction,where should I build tulsi vrindavan excep
Last answer on 9/30/2020 4:21:59 AM. by S L Gupta (Civil Engg). Forum started by ashish
3178
i am a dentist i want help on how to arrange my dental chair and wher should b m
Last answer on 12/1/2021 8:28:45 PM. by Hikkler. Forum started by tushad kannekar
3558
2271
I have not received any sggestion regarding my earlier question about our flat n
Last answer on 10/12/2021 6:24:29 AM. by Priti Arora. Forum started by subrahmanyamkvs
2705
i in kuwait and iam stying in one room where to keep cash box?
Last answer on 9/7/2021 3:50:41 AM. by Kaliopsy. Forum started by rafimeer
2382
pl send me40feetlenth 30feet berth plot, 850feet(or)900feet 2bhk north(or)east f
Last answer on 8/24/2021 3:22:22 AM. by S L Gupta (Civil Engg). Forum started by nagarajan.n
3353
2923
I need layout for making duplex for east facing plot 30 x 50 bedrooms with attac
Last answer on 2/26/2021 4:04:46 AM. by S L Gupta (Civil Engg). Forum started by devinder
3053
can a vastu expert go for bet for best results by vastu remedies ?
Last answer on 2/25/2021 4:27:09 AM. by S.Krishnan. Forum started by harbans singh sekhon
2387
hi ............... i want bed room cupbords designs,plese sand me.
Last answer on 2/8/2021 11:49:19 PM. Forum started by vijay
2447
My plot size is 35by70 .give me map layout diagram. Ground floor for 2 portion o
Last answer on 2/8/2021 11:45:07 PM. by S L Gupta (Civil Engg). Forum started by hemant yogi
5517
Last answer on 1/26/2021 5:40:38 AM. by VastuMoorthy. Forum started by srihari pagadala
2476
Your name :Srinivasan Email adds:vasan09@gmail.com
Last answer on 1/18/2021 9:48:48 PM. by seema tyagi. Forum started by Srinivasan
3966
Last answer on 12/31/2020 2:45:49 AM. by VastuMoorthy. Forum started by senorita
2941
My Plot size is two sides open with two roads at southeast & northeast side of p
Last answer on 12/31/2020 2:31:46 AM. by harbans singh sekhon. Forum started by kstomar2001
3825
Last answer on 12/31/2020 2:29:53 AM. by POSAM BHASKARRAO. Forum started by Sanjeev Saran
2796
Last answer on 12/31/2020 2:14:53 AM. by krishna. Forum started by trisha
2852
Last answer on 12/31/2020 1:54:01 AM. by prasad. Forum started by kalpana sharma
6148
Vastu and Brahmasthan
2010
What will may be full construction estimate cost plot size of 25*45, pl send me
Last answer on 7/4/2020 3:43:22 AM. by S L Gupta (Civil Engg). Forum started by mahendra kumar dutta
1884
Kitchen is in south east and dinning in west. It won't work.
Last answer on 7/3/2020 11:38:06 PM. by S L Gupta (Civil Engg). Forum started by ashok
2117
my date of birth 01-06-1958 vich is my good direction pls
Last answer on 7/3/2020 10:55:27 PM. by S L Gupta (Civil Engg). Forum started by anjaneya
Porch
Porch Designs
Fire
Orientation
Orientation of Building
Design
Design your Office
Environmentally
Environment
Environment Friendly Houses
