Sat Feb 08, 2014 | Total posts : 1 |
| Topic: Laminate Glass for Wooden Windows
Hi I have wooden window frames in my house, which are about 30mm thick. I would like to change the glass currently in these windows to laminate glass. The glass is currently of size 4mm. I would like to have laminated windows, to reduce outside noise. My questions are: 1) What is the recommended thickness of the window frame, if the laminate glass is about 9mm thick. (I am aware that just laminate glass will not reduce noise, but I cannot replace my wooden window frames without incurring cost and mess). 2) How much thickness of laminate glass can the current 30mm wooden frame hold. The wood is "honne"...that is what it is called here in Bangalore. The laminate glasses are available of size 9mm and 13mm and higher. So a 30mm thickness may or may not hold it. 3) What other solutions do we have to put in laminate glass to already existing windows.
Thank you Ashok
Sun Feb 09, 2014 | Post #1 | Abhishek Garg (Builder & Engineer)
Join date: Apr 2013 | Post subject: Soundproof Laminated Glass Window
Dear Ashok: Keeping the same window frames, you have two options: 1) Install laminated glass instead of your current glass. You say that the thickness of the window frame is 30 mm. You can easily put 9 or 13mm glass in the frame depending upon the location of the glass slab within the 30 mm space. Usually the glass is not placed in the center of the space so the wooden beading that is holding the glass from outside will start to come more and more towards the outer side as we keep on increasing the glass thickness. 2) Second solution is to install two glass sheets per window. Let the current 4mm glass be at its place and remove the current wooden beading. Secure the 4mm glass with a new wooden beading about 4mm thick. Put another 8mm ordinary glass sheet against this 4mm beading. Finally secure this 8 mm glass with the original beading. I hope it helps. | |
Wooden Windows-Construction Questions (20) | |
1882 views | 2 answers | Last answer on 10/5/2014 11:17:43 PM. by JAI PRAKASH. Forum started by Anil Sangwan | 2724 views | 0 answers | Last answer on 9/19/2012 7:46:20 AM. Forum started by disha gupta | 2593 views | 2 answers | Last answer on 5/26/2021 7:46:03 AM. by mnabeel_80. Forum started by deepa sangal |
| 5226 views | 3 answers | Last answer on 7/3/2020 10:59:57 PM. by S L Gupta (Civil Engg). Forum started by ASIM DE | 2731 views | 2 answers | Last answer on 7/25/2013 5:15:06 PM. by LAKWINDER. Forum started by sunita | 3052 views | 2 answers | Last answer on 5/30/2013 11:04:45 AM. by S L Gupta (Civil Engg). Forum started by oscar | 2525 views | 2 answers | Last answer on 7/31/2014 1:12:56 AM. by JAI PRAKASH. Forum started by dspatwal | 2637 views | 1 answers | Last answer on 7/3/2020 10:30:41 PM. by Nikita. Forum started by dineshdesme | 2786 views | 1 answers | Last answer on 12/31/2020 2:29:52 AM. by Deepti. Forum started by ranjit | 1967 views | 2 answers | Last answer on 2/16/2022 8:32:26 AM. by jackthot. Forum started by awdhesh | 1868 views | 1 answers | Last answer on 9/5/2014 8:02:17 PM. by JAI PRAKASH. Forum started by subir | 2181 views | 1 answers | Last answer on 9/11/2010 11:27:22 PM. by sachin. Forum started by Mahendra Agarwal | 2483 views | 1 answers | Last answer on 7/12/2011 10:22:48 PM. by Gunjan Utraja. Forum started by mona | 3597 views | 3 answers | Last answer on 1/4/2012 12:37:42 AM. by pallubc2. Forum started by pallubc2 | 1831 views | 1 answers | Last answer on 3/19/2021 12:11:38 AM. by S L Gupta (Civil Engg). Forum started by Dechamma | 2930 views | 0 answers | Last answer on 7/10/2011 8:45:13 PM. Forum started by Vinod | 3691 views | 1 answers | Last answer on 2/1/2014 4:49:18 PM. by Navneet Jharia. Forum started by Unnikrishnan | 4179 views | 2 answers | Last answer on 11/10/2021 8:22:17 PM. by Girish. Forum started by Girish | 3611 views | 0 answers | Last answer on 7/3/2020 10:22:49 PM. Forum started by raghuam | 9364 views | 3 answers | Last answer on 6/2/2013 8:47:24 PM. by Navneet Jharia. Forum started by Arun |
Articles that might interest you! | | Architectural Shingles If it is time to replace your roofing, ask about architectural shingles.Laminate shinglesor architectural shingles are.. | | Types of Glasses A variety of glasses enriches interiors and exteriors of house and serves the purpose of light, ventilation and decora.. | | What are various types of window glasses recommended for home? Many types of glasses recommended for homes are following: Obscure Glass,Tinted Glass,Tempered Glass
| | Glass window finishing materials For glass window, verity of finishing martial available in the market. Here is a complete description of all the finis.. | | Decorate Your Home with Stained Glass Stained glass introduces sense of artwork and offers matchless beauty to the interiors of home. The glass can perk up .. | | What is Glass Window A transparent opening in a wall is called window. Usually windows are covered by transparent or glazed material like g.. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | Bathroom Design in Glass Glass never goes out of style and creates an absolute amazing and interesting environment within your bathroom. If you.. | | Comparing uPVC Windows with Wooden Windows and Aluminium Windows Comparing uPVC Windows with Wooden Windows and Aluminium Windows | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
