Bricks
Mon Jan 16, 2017
Topic: Laying one row of clay bricks on top row of solid concrete brick wall for height correction?
My contractor use clay bricks for the top row of solid concrete brick wall of ground floor for height adjustment to 10 feet. Is it technically ok? Is there any issues in mixing concrete bricks and clay bricks in wall construction?
Mon Jan 16, 2017
Dear Vinu,
There is no harm to use clay bricks. Do the masonry in cement mortar 1;4 with all joints properly filled.
3008
2154
2867
Bricks
Last answer on 1/16/2013 11:34:07 AM. by
shahidain
3996
Last answer on 7/25/2013 5:11:37 PM. by
LAKWINDER
shahidain
1800
1322
I have east facing dupleix row house with one sharing wall with next row house.
Last answer on 5/16/2017 5:28:56 PM. by
sunita
2875
FLYASH OR CLAY BRICK
Last answer on 12/3/2013 11:46:22 AM. by
Abhishek
3462
Last answer on 9/17/2012 8:35:35 PM. by
piyush
Kinley Tshering
9210
Vinod
3086
Last answer on 2/25/2014 6:35:09 AM. by
manish
jagminder
3124
concrete brick or clay brick
Last answer on 9/6/2012 10:57:35 AM. by
pallubc2
pallubc2
1531
Last answer on 10/3/2017 7:03:56 AM. by
gautam kumar
gautam kumar
1848
Last answer on 11/3/2016 2:26:29 PM. by
3438
amit yadav
amit yadav
6459
Last answer on 10/8/2011 10:00:53 AM. by
Vinod
3150
Last answer on 8/16/2013 1:12:41 PM. by
K S SHYAM SUNDER
1887
discussed about the estimate of of bricks in a wall in one square foot
Last answer on 5/20/2015 5:28:35 PM. by
bittushaikh
1866
Last answer on 1/5/2022 9:14:05 PM. by
sanjay agarwal
saradha
7518
Brick Advice Urgent
pmarple
pmarple
2885
Bricks
Chandrasekaran S
2797
brick calculation
Last answer on 4/14/2021 6:20:51 PM. by
Gagandeep
2570
Cost of Brickwork
Last answer on 12/31/2020 2:51:43 AM. by
Abhijeet Shinde
4901
Last answer on 8/29/2020 12:29:33 PM. by
Kalayart
Vishal Thakur
2824
srinu
2351
Vikas
3172
bricks
Last answer on 7/3/2020 11:33:47 PM. by
drkksuresh
drkksuresh
5664
Last answer on 7/3/2020 10:43:26 PM. by
sunny420
2017
Last answer on 7/3/2020 9:20:34 PM. by
Alfred
Akshay
3240
Last answer on 6/19/2019 10:21:22 PM. by
Sanzana Hosen
5137
Use of Solid Concrete Bricks
aravind
Kinley Tshering
1630
Last answer on 1/20/2017 3:47:17 PM. by
1848
1482
Last answer on 8/24/2016 12:13:52 PM. by
1800
2968
fly ash bricks
Last answer on 5/26/2016 3:10:41 PM. by
santhosh
2240
Last answer on 5/3/2016 12:34:16 AM. by
sayeedmohsin
1727
Techman
Various Types of Bricks
Brick Arches
Specification of Brick
Concrete Mix Ratio
Brick Pillar
