Home -> Forums -> Interior -> Home Improvement -> Leakages in Apartment
Wed Dec 09, 2015Total posts : 5
nitin_patel
nitin_patel
Topic: Leakages in Apartment
A 3 Bed Room  apartment on 6th Floor (Total Eight Storied)
around 12 years old,is showing seepages and moisture movements on
walls.As a remedy.,the walls of Drawing hall were tiled up to 3 feet so that moisture is contained in side only.The upper part was painted.
Now the painted wall has again shoen the signs of flaking of paint due
to moisture movements within the wall.
What is the best remedy to have permanent solution to this problem?
Pls. suggest.
Thu Dec 10, 2015Post  #1
Is there any pipe going from that wall? If yes have it checked, if not check the quality of plaster on the other side and have it repaired/re-done for any issues. The issue is only in your flat or in all? The issue is in all walls on only 1? Install tiles till roof if possible.
Thu Dec 10, 2015Post  #2
Dear Patel
        First of all see this seepage problem is only in your flat or on your upper or down word side flat. Tile fixing is no solution to the problem as moisture go up side due to capillary action, Find out the root cause of seepage. Seepage may be due to leakage in water supply pipe  line or leakage in toilet block, or leakage in rain water pipe fixed in wall or leakage from top roof during rainy season or overflow of water taken.
Thu Dec 10, 2015Post  #3
nitin_patel
nitin_patel
Dear Shri Jay Praksh and Shri Guptaji,
At the outset,thanks so very much for your responses.The problem  of leakages is being faced in almost all the flats of the tower,which is 8 storied building,whereas mine is 6th Floor.
You are absolutely right Guptaji,that we need to find out the root cause of the leakages problem.I thought of a proposal wherein ,all the concealed water lines are made non operational (within the flat's toilets) and install new Open lines,so that if the dampness in walls is caused by leakages from within the walls it can be arrested.
Pls. give your valued opinion on the same.
Also,suggest some alternative remdial measure.If required,I can forward the requisite snaps for your reference.
Thanks once again.
Fri Dec 11, 2015Post  #4
Dear Patel
        In my opinion first contact any good plumber and see that what solution or short coming or problem he finds after inspecting the house or flats..After that go for alternate solution of open pipe line.
Also check that in toilet mainly where Indian WC are fixed leakage in WC and P or S trap joints start and damaging the adjoining wall.
Also see that seepage is continue or increase or decrease as per rainy season.
Do proper exercise before doing any solution.
Sat Dec 12, 2015Post  #5
Hire a good plumber and go ahead.
3350
2522
How to arrest leakages through expansion joints.
Last answer on 11/20/2009 10:16:24 AM. by Girish. Forum started by Jagadesh Babu
2283
3105
3558
2921
i want desings of fall ceiling in apartment flat
Last answer on 3/12/2021 10:49:40 PM. by G N Shaikh. Forum started by shrenik
1863
Is a apartment block anti-vaastu if it has a pond on its south
Last answer on 3/5/2021 2:56:01 PM. by JAI PRAKASH. Forum started by siddhartha
1887
apartment or house can be in vertical size..
Last answer on 3/5/2021 2:57:28 PM. by seema tyagi. Forum started by shankartenugu
1022
apartment or a house
Last answer on 5/14/2022 7:39:46 AM. Forum started by Kirow44
1682
I have seen an old apartment put up for sale. The entrance of the Groundfloor ap
Last answer on 1/27/2022 12:33:26 AM. by S L Gupta (Civil Engg). Forum started by Reenu
2916
2305
3962
Roof leakage
roof leakage
3608
Wall unit
1803
Need advise on any Vastu dosh with layout
Last answer on 8/21/2020 7:33:22 PM. by S L Gupta (Civil Engg). Forum started by Kanika
2038
Ideal place to keep Mandir / Pooja ghar
Last answer on 3/27/2015 9:49:44 PM. by Pavan. Forum started by Taneesha Keer
2602
Vastu of the attached flat
2333
Refinish a Vinyl Floor
2505
Introduction
1073
Home appliances
2347
2948
layout plan
2167
Window Curtains For Home
3406
Reg: Interior design software
4733
2700
Living Room Decoration Ideas
2214
2017
2201
floor tiles
771
Online dating
2524
4013
Paint vs Wallpaper
2495
Design for a pooja room
9515
Wall Putty and primer
1994
Straight Drop Awnings
2741
Kids Room Theme
1998
sapty tank
Electric
Preventive
ACC
ACC Sheet Roofing
Importance
