Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Load Bearing to RCC framed Structure
Tue Apr 02, 2013Total posts : 2
Ambuj
Ambuj
Topic: Load Bearing to RCC framed Structure
I have a 474 sqft. (12'*39.5')sqft 2 and half story house with load bearing structure. Now I want to construct 2 additional floor on that. As the existing structure (12' x 2 nos. wall 9",12' x 3 nos 4.5" thick and 39.5' x 2 nos. 4.5" thick) is load bearing so can I:
  1. Make column from ground floor by cutting in wall and ceiling and joining the new steel bars with existing RCC slab to take load of  2 additional floor.
  2. Make tie beam at ground level by cutting the wall horizontally in segment wise to support the columns.
  • Is this exercise is practical? will it take load of additional 2 floors or I should make a new construction after dismantling the existing structure?
  •  If this is possible then I can save money for construction and I can use the existing floors.
A. K. Ajad
Wed Apr 03, 2013Post  #1
Dear AK
         In my view, it is better if you contact any local civil engineer / structural engineer of your city, who will visit the site and take appopreate decison for loading condition and also see the strength of existing structure, type of foundation and its strength etc.
Wed Oct 15, 2014Post  #2
As the built structure is load bearing  dont go for any changes, also no need to demolish any part, we have to provide RCC columns around the all four sides.with tie beams and columns upto  slab .Get it designed. there is not big problem
2210
2256
2616
COLUMN nd LOAD BEARING
1747
2525
7927
1764
4925
LOAD BEARING STRUCTURE
4128
3941
6532
Load Bearing vs RCC frame
Last answer on 7/3/2020 11:34:17 PM. by S L Gupta (Civil Engg). Forum started by DK
3002
House Estimation Breakdown
7257
10047
3013
2132
Load bearing
Last answer on 1/17/2014 12:05:30 PM. by S L Gupta (Civil Engg). Forum started by Syed Shahed
3424
2427
RCC ROOF Requirements
Last answer on 5/22/2013 8:47:10 AM. by Rajesh. Forum started by Rajesh
14599
5811
3792
9885
2670
4627
4143
2865
5006
3656
1865
2800
2610
2372
2462
2638
1807
3608
6254
Door
Door and Window Frames
