Minimum rest/gap period
Thu Dec 01, 2011
Manish
Topic: Minimum rest/gap period
i started constructing the ground floor of my duplex on 24th oct. 2011. My construction pattern is 'confined Mansonary' (RCC 1:2:4) . The foundation work was completed on 20th nov. The brick work was finished (ratio 1:6)on 30th Nov.
Now i want to know that how much 'rest period' should be given before lintel. my contractor wants to construct lintel on 15th Dec. and he wants to start the brick work for the second story on 1st Jan 2012. & the lintel of second story by 30th Jan 2012. Will this 'time gap' be correct /sufficient or not.?
Tue Dec 06, 2011
ravi at Dalmia
Hi Manish, 15 to 20 days is an appropriate time for lintel setting after the bricklaying process. However do get it cross checked from your contractor and if needed from an expert who can actually visit your site and examine. Also check for some construction manuals on internet which would provide you relevant information. Good luck !
1505
Can you recommend me how to create nice writing works in a short period?
Last answer on 2/24/2022 4:19:48 AM. by
Alexander Graf
Bill Shiphr
2345
my question is can we built one temple beside my home just one feet gap
Last answer on 9/8/2010 1:01:25 PM. Forum started by
Rajashekar
2362
minimum size of area for bath
Last answer on 3/20/2011 1:47:39 PM. Forum started by
DURAISWAMY.G
2453
Last answer on 8/6/2011 2:32:51 PM. by
nita
1885
Last answer on 11/3/2016 10:40:18 AM. by
shashi
7290
Last answer on 7/4/2020 2:54:21 AM. by
gautam kumar
2613
roof thickness
Last answer on 2/26/2022 9:17:15 AM. by
gautam kumar
8910
Last answer on 1/21/2021 1:04:07 AM. by
karthik
Rahul
2957
Last answer on 7/3/2020 11:16:01 PM. by
ghouse
2234
Iam rajashekar, my question is .Can we built one temple beside the house. (just
Last answer on 9/8/2010 12:56:07 PM. by
Rajashekar
2787
Plaster work
Last answer on 2/15/2022 8:09:55 AM. by
AleksShamles
Alok Das
2106
Last answer on 2/14/2021 11:35:17 PM. by
Ravi sharma
2116
I m constructing my house in DURGAPUR (W.B.).WOULD LIKE SOMEONE TO HELP ME FOR S
Last answer on 12/7/2010 10:00:13 AM. by
SHEKHAR
2808
i need an information regarding the minimum cost of a wall decor with painting..
Last answer on 8/4/2018 2:36:29 AM. by
anoo
4409
I would like to know How much Minimum maintain the re inforcment spacing in the
Last answer on 12/31/2020 2:22:36 AM. by
Girish
tkalaiva
2353
How to Maintain Air Conditioner?
Last answer on 6/29/2021 4:36:51 AM. by
DavidFlores18
V K GUPTA
2000
plz let me know d minimum area& approx cost.
Last answer on 6/17/2010 2:39:02 PM. by
ADARSH
ADARSH
3431
Last answer on 1/15/2022 4:20:05 AM. by
kumar
25619
CURING TIME FOR RCC ROOF
Last answer on 5/18/2013 1:47:17 PM. by
Rajesh
2482
Cupola Proportions
Tips for cupola proportions
