Home -> Forums -> Construction -> Cement Plastering -> Name to chemical that helps new plaster to bind with the wall after removing the old plaster which has cracked due to earthquake
Tue Nov 08, 2011Total posts : 1
timm todd
timm todd
Topic: Name to chemical that helps new plaster to bind with the wall after removing the old plaster which has cracked due to earthquake
The plaster in my house cracked due to earthquake. I want to remove the old plaster from the wall. After removing the old plaster I want to plaster only the old cracked removed portion with fresh plaster.
What is the name of the chemical that help new plaster to bind with the old wall? What should I do to ensure that the new plaster glues to the wall properly as if it was the old plaster.
Tue Nov 15, 2011Post  #1
Dear Timm
      On old wall, scrap the plaster and remove all loose material first by wire brush and then by hard brooming. After thatwall should be clean with washing with water.As per my view no chemical is required, apply cement shullery on wall before applying cement mortar and finish throughly. Take help from gharexpert construction section where in finishing exist the plaster procedure in detail.
Cement Plastering -Construction Questions (39)
3436
sunmica
Last answer on 12/6/2012 10:52:25 PM. by shailesh kumar singh. Forum started by tanaji
3380
Recurring Cracks
4629
time for paint and wall putty
2438
Gypsum Plaster Vs S/C Plaster
8880
3992
7006
2339
11300
2212
Painting interior walls
962
SIR,I have made new home and i am staying there for last two months. RCC ground
Last answer on 9/7/2018 1:08:09 AM. by S L Gupta (Civil Engg). Forum started by kajal dutta
1739
weather proof repair reg
2781
Plaster work
1599
2084
2073
2131
Walls are damp in rain
2107
3457
2929
Plaster
2781
Plaster work
3048
Plastering
1925
2006
PPC and OPC cement
11300
1871
suggest for exterior
7006
9158
1878
OPC and PPC cement
2158
2012
coarse aggregate
1826
Nice
2438
2174
Outer Plaster
2997
2735
putty work on walls
2236
2827
2033
Surface
How To Repair Cracks
Checklist for Cement Plaster
Gypsum
Plastering
Plastering
Specification of ‘Plastering’
How to clean plaster ceiling?
