Sat Aug 24, 2013 | Post #1 | S L Gupta (Civil Engg)
estimate will be give after the plan of the building, first final your
building plan and specification to be used in construction. If you want
rough cost estimate than use Estimator given in the gharexpert.com
website. Link given below
http://www.gharexpert.com/Estimator/Startpage.aspx | |
Sat Aug 24, 2013 | Post #2 | ragha
Join date: Aug 2013 | Post subject: Need help for Cost Estimate of RCC Pillars and R...
Hello Sir,
Thank you sir. I tried using the estimator,but i could not find the RCC pillar section.
As of now i have little funds...so is it possible to at least start with the RCC pillars and roof for an area of 30*50. May be 1 or 2 years later i will plan for the actual house on the roof.
regards ragha | |
Wed Sep 04, 2013 | Post #3 | wasim
Join date: Sep 2013 | Hello i am planning to construct rcc roof with 12 pillars on 1st floor,i want to know how much it costs
Thu Sep 05, 2013 | Post #4 | S L Gupta (Civil Engg)
Join date: Mar 2008 | Dear Ragha The estimator is used to know the construction cost of the building ,it not tell the size. The size is found in the drawings. You can go ahead with pillar and roof construction and finish the house according to fund availability.
Thu Sep 05, 2013 | Post #5 | S L Gupta (Civil Engg)
Join date: Mar 2008 | Dear Wasim Cost can be calculated with the sizes of member i.e. pillar, beam and slab etc and what ratio of cement concrete use in it.
Thu Jul 03, 2014 | Post #6 | Muhammad Rizwan
Join date: Jul 2014 | Asalam-o-Alaikum! Dear, you want the estimate of R.C.C work ...I will tell you if you tell me the size of Roof & Pillars... Thank you... | |
Brick Walls, Pillars and Structure-Construction Questions (39) | |
