Overhead water tank - above head room roof
Sun Jun 02, 2013Total posts : 2
muthuraj
muthuraj
Topic: Overhead water tank - above head room roof
Overhead water tank-Initially we advised him to construct it above the head room by providing a pillar for 3 feet high.
But, my contractor constructed the overhead water tank on the roof of the head room.
The justification he is providing to us is that he made the thickness of the roof to 7” and provided double mat (two layer of slab) RCC roof. Also, Dr. Fixit (water leak) solution was applied while casting the roof.
Kindly advise whether the method what he is telling is good or the roof will absorb water, moisture. As the construction is going on we can correct it right now.
Mon Jun 03, 2013Post  #1
Dear Muthuraj
          It is better if there is a gap between roof slab and overhead water tank slab. What ever caution to be taken but moisture destroy the MS steel bars as they are rusted due to moisture.
Mon Jun 03, 2013Post  #2
muthuraj
muthuraj
Thank You very much
2388
1728
1934
1967
Over Head Water Tank
2920
Last answer on 4/11/2017 11:10:57 AM. by S L Gupta (Civil Engg). Forum started by vinu
roofing on open terrace
10027
OVERHEAD WATER STORAGE TANK
Last answer on 3/13/2013 1:37:46 AM. by Purvi Panchal. Forum started by Purvi Panchal
1774
5055
5629
Over-Head water Tank
1877
sir, My house overhead tank loation is north west, please suggest me.
Last answer on 1/1/2013 6:19:15 PM. by Pavan. Forum started by kuldeep
2647
1437
I need help! How do I seal a leak from my overhead tank?
Last answer on 8/8/2017 11:57:23 AM. by S L Gupta (Civil Engg). Forum started by Arun
2959
Last answer on 9/1/2015 2:51:50 AM. by JAI PRAKASH. Forum started by sher singh daulta
2023
3368
2322
Overhead water tank design
Last answer on 10/26/2016 12:48:05 PM. by S L Gupta (Civil Engg). Forum started by Rakesh
3753
Vastu for Water Tank
Preventive
Shower
Shower Head - A Stylish Bath Experience
Shower heads shower the water over the top of your body just like rain water and give a delightful feeling to you. The..
