Fri May 17, 2013 | Post #1 | Abhishek Garg (Builder & Engineer)
Join date: Apr 2013 | Hi: Alternatives to conventional cement plaster: for interior walls - gypsum plaster; for ceiling - POP, gypsum board, PVC panelling etc. Tiles can be put on walls but that would again be a sand-cement-water activity. I hope it helps. | |
Sat May 18, 2013 | Post #2 | Navneet Jharia
Join date: Dec 2010 | Post subject: ALTERNATIVE? PLASTERING of Walls & RCC Roof
POP, Gypsum board, falls ceillings,wall penelling, Alluminium panel sheets etc, are the alternates ,but all these are Temporary solution,,
Sat May 18, 2013 | Post #3 | Rajesh
Join date: Apr 2013 | Dear Abhishek & Navneet- Thanx for your prompt answers.
I agree that tiles will again be sand-cement-water activity but I still think they will be the best and least fussy options compared to cement plastering considering the plastering process and it's curing time. Tiles will also save future painting of the walls.
Can wall tiles be pasted directly on the bare brick walls or still need that cement-bajarpur base?
Thanx Rajesh
Sun May 19, 2013 | Post #5 | Ravi
All the above alternatives works and gives finishing, but before applying any of these, you will just
have to make it sure that walls or RCC roof are not having any types of leakages or hairline
cracks, which may lead to bad results or may
damage POP, Gypsum board, falls ceilings, etc. In case of leakages or cracks it becomes very much compulsory to do Plastering.
Sincere Regards
Ravi
Mon May 20, 2013 | Post #6 | Rajesh
Thanx much for your advise and I think I am all set now with enough information to start the construction.
Regards Rajesh
Mon Nov 06, 2017 | Post #7 | Mohit Jalan
Plaster in my flat fallen down in hammer test whole flat is failed as the contractor did not removed plastic from slab. Now I need to replaster my complete dalt. Curing the plaster will destroy my furniture’s. Any alternative othe gypsum plaster and false celling. Any additive or any other solution to save curing | |
Wed Nov 08, 2017 | Post #8 | S L Gupta (Civil Engg)
Join date: Mar 2008 | Dear Sir, If you do not want gypsum plaster or false ceiling. Than Beside curing of plaster, for doing plaster you should protect the furniture from plaster mortar dropping at the time of applying plaster on roof ceiling. To protect that you should cover the furniture with polythene etc. Now for curing you should adopt the curing method by 4'' or 6'' painting brush and apply water with brush like paint but this will be expensive but save your furniture.
Cement Plastering -Construction Questions (38) | |
