Home -> Forums -> Construction -> Outdoor -> Pergola beams steel vs concrete
Mon Aug 27, 2012Total posts : 10
PR Jawahar
PR Jawahar
Topic: Pergola beams steel vs concrete
I have a requirement of making pergolas for my proposed house. Considering the safety it can be made only in Steel or Concrete. I would like to the know what would be the approximate cost comparison between this. Considering the maintenance aspect my inclination is more towards concrete beams. Please provide your valuable inputs.
Mon Aug 27, 2012Post  #1
P R Jawahar
            Cement concrete paragolas are cheap than MS steel paragolas.
Tue Aug 28, 2012Post  #2
Ar. Manoj Ralen
Ar. Manoj Ralen
Dear PR,
Also from the maintenance point of view, RCC pergola structure will be easier to maintain.  I'll try to find out the cost comparison between the two and update.  Does any one else has some ready made numbers for these?
thanks
Thu Aug 30, 2012Post  #3
PR Jawahar
PR Jawahar
Post subject: Thanks for your answers
Thanks for your answers. I am considering a cross section of 100mm x 150mm for a span of about 8 feet. Since the beams would not be loaded, I guess this would be sufficient to hold its self weight with some reinforcement. Kindly confirm
Fri Aug 31, 2012Post  #4
Dear Jawahar
     As stated by you, the section of pergola 100mmx 150 mm is sufficent for 8 feet span. Use 12 mm dia MS steel bar 4nos with 6or 8mm rings 3'' center to centre. use cement concrete 1;1.5;3 mix and do proper curing.
Fri Aug 31, 2012Post  #5
PR Jawahar
PR Jawahar
You are so helpful Mr. Gupta. Appreciate your detailed response..
Sun Nov 29, 2015Post  #6
shriramk1986
shriramk1986
Hello all,
I am planning to construct my house.  I am planning to build a pergola.  Usually how is pergola charged to the customer by contracters?  Whether it is on square feet basis? I am planning for a RCC pergola with steel running within it.
Thanks in Advance
K. Shriram
Mon Nov 30, 2015Post  #7
Dear Shriramk
              The contractor charge as per agreement. If this point is silent than contractor try to get more and charged for square meter which is more or less correct.
Mon Nov 30, 2015Post  #8
shriramk1986
shriramk1986
Dear Gupta Sir,
Thanks for the information.  The agreement does not speak about pergola. If he charges according to square feet, should it include the entire area? For example I want a pergola to be constructed in an open area of dimensions 12 feet by 6 feet.  I want 3 straight rods of thickness 0.5 feet and length 12 feet in this 12 by 6 area.  In this case what is the general practise? Does the contractors charge for (12 *6 = 72 square feet) or it should be for (12*0.5 * 3 = 18 square feet)?  My contractor was saying he would charge for 72 square feet at the mentioned rate of my contract which is 1800 per square feet for the entire house.  Please advise me if this is fair enought.
Thanks in advance.
Tue Dec 01, 2015Post  #9
Dear Shriramk
          Your agreement is on trough rate base where area have very much significance for cost if it is on labor than no much concern. This way you have to pay in lacs for some thousands. It is better drop the idea for some time and do this after completion form other agency by arranging material by yourself  and mason fix it and you will not to spend more than 10% of cost as demanded by your contractor.
Tue Dec 01, 2015Post  #10
shriramk1986
shriramk1986
Thank you so much sir for your kind suggestion.
2310
New Pergolas Design For Your Home
Last answer on 5/28/2015 10:09:11 AM. by berashton. Forum started by berashton
3271
Roof Concrete Strength
3720
5017
2519
15582
13772
overlap length to steel
2685
Steel Size
Last answer on 8/21/2014 12:31:17 PM. by S L Gupta (Civil Engg). Forum started by ferous
2036
2707
2301
2032
5691
1709
Driveway Reconcreting
Last answer on 1/23/2016 8:41:13 PM. by JAI PRAKASH. Forum started by gpeter
1311
2394
How to Pick Out The Right Modern Pergola Designs For Home
Last answer on 6/16/2015 4:29:43 AM. by JAI PRAKASH. Forum started by berashton
9195
3327
Design of RCC Pergola Beams
Last answer on 6/16/2015 4:18:19 AM. by JAI PRAKASH. Forum started by Tony
4027
Last answer on 6/16/2015 4:18:15 AM. by JAI PRAKASH. Forum started by Tony
2866
Steel calculation
1758
6693
11377
10721
Life span of RBC lintel roof
2090
Foundation
3569
R.C.C. column in Sqft
2279
Plumbing works
1588
New 4 storey building design
1905
earth filling under floor
1774
want a parking
2404
2268
2565
foundation plan.
Last answer on 12/15/2011 2:31:13 PM. by Ishmael Mphande. Forum started by Patrick Salasini
2624
Last answer on 12/6/2011 7:58:37 PM. by Manish. Forum started by Manish
2501
Re-Construction
3014
cracks in walls
Designing
Designing a Pergola
Pergolas are nice places to relax and entertain with family. Pergola add style, art and structure to the exterior of y..
Centering
TMT
Type
Concrete Decor
