Home -> Forums -> Construction -> Brick work -> Protecting concrete brick boundary wall without plastering in rainy season?
Tue Nov 01, 2016Total posts : 1
Topic: Protecting concrete brick boundary wall without plastering in rainy season?
I'm from south india where almost all boundary walls are constructed using 4" thick concrete bricks and plaster both sides to protect the bricks from heavy raining season. Since plastering the whole boundary wall is a costly affair, I am looking for alternate cost effective methods to protect the concrete bricks from rains. Someone told me that brushing a thick white cement coat on both sides is enough and save the cost of plastering. Is it ok, and any other methods also?
Wed Nov 02, 2016Post  #1
Dear Vinu,
          White cement is costly, use grey cement with lime and for beauty do white washing after curing and drying the wall.
2084
2132
Walls are damp in rain
2074
2107
2994
1875
2863
Need help regarding boundary wall construction
Last answer on 8/27/2013 11:59:55 AM. by S L Gupta (Civil Engg). Forum started by sonu.211
3082
2153
1846
3843
3470
Cost of concrete walls
6471
3457
3670
wals
9198
1739
weather proof repair reg
1966
3670
wals
3264
compound wall
21879
3280
Bedroom Wardrobes information
2246
2207
1495
1966
1733
2225
1502
1910
Brick or ACC block
1654
2153
1702
4688
Brick wall on RCC slab
3930
2618
How to clean plaster ceiling?
Plastering
Plastering
How To Repair Cracks
Concrete Mix Ratio
Centering
Gypsum
Checklist for Cement Plaster
