Wed Feb 05, 2014Total posts : 1
vamsi
vamsi
Topic: Query about the slab plastering
I have the below query about my house slab plastering work. I searched internet and did not find any information.
Slab is done and for the plastering to the slab flooring,the builder said he is going to do the below way
First lay bricks side by side for entire slab and then fill the gaps with sand,cement and then on top of it he is going to do plastering. He said this way it helps to cool the house.
is this correct way of doing it? Does it really has any advantages/disadvantages
Plese advise.
Sat Feb 08, 2014Post  #1
Post subject: Finishing the Roof Slab
Hi Vamsi:
From what I have understood from your question, I am assuming that you are asking about finishing the roof of your house.
While there are various methods to finish the roof depending upon one's taste and budget, I will be talking about the most common medium i.e. brick tiles for roof.
After applying a proper water-proofing coat over the RCC slab, cover the slab with mud with proper sloping into rain water pipe(s), lay 1" thick layer of wet mud mixed with bhusa/phuska/tudi and fix brick tiles over this layer with wet mud. Finally use cement+sand mix to teep the groves of these tiles.
I hope it helps.
1789
like an answer to my query as it is important.drsingh
Last answer on 9/5/2010 11:55:20 PM. by Gunjan Utraja. Forum started by dr singh
1639
sir i have a query how can i contract
Last answer on 1/10/2016 8:48:39 PM. by JAI PRAKASH. Forum started by VINAY
2572
sir i have a query how can i contract my email id is vsp106@gmail.com
Last answer on 10/11/2021 4:59:19 AM. by JAI PRAKASH. Forum started by VINAY
2924
1664
My slab plaster is spilling and reinforecement is little wrotten,i try to plaste
Last answer on 11/4/2010 7:43:55 PM. by balendu. Forum started by nith_piyush
9893
2866
Steel calculation
1758
Cost of RCC ceiling plaster repair due to spalling
Last answer on 10/6/2014 12:46:05 PM. by S L Gupta (Civil Engg). Forum started by LM
1930
cost of RCC ceiling plaster repair due to spalling
Last answer on 10/7/2014 11:28:14 AM. by S L Gupta (Civil Engg). Forum started by LM
4629
time for paint and wall putty
2781
Plaster work
2438
Gypsum Plaster Vs S/C Plaster
1981
Last answer on 10/27/2015 10:43:31 PM. by JAI PRAKASH. Forum started by Baba Dedge
2149
Sunken slab
Last answer on 1/17/2021 5:51:16 AM. by freekundli. Forum started by Bhaskara
2563
4056
6694
17
Checklist for Cement Plaster
Gypsum
Centering
Specification of ‘Plastering’
How to clean plaster ceiling?
Plastering
Plastering
