Thu Feb 27, 2014 | Total posts : 2 |
| Topic: RCC Column Construction
Dear Shri Gupta,
First of all, allow me to CONGRATULATE YOU, it is a stupendous job that you are doing, dispensing such wonderful advice gratis to all of us !! Marvellous indeed !!
I have the following queries:
I have recently started construction of my house in NOIDA (renovation and extension actually). Footing work of pillars has been done and pedestal work is about to be started. I find that the four vertical bars (16mm) are twisted in the vertical plane to about 20-25 degrees. At the base, the toe of the vertical bars were properly aligned - all in one direction, but at GL height they appear twisted. If I rotate the tie ring horizontally, the four bars now appear properly aligned at right angles to the boundary. The contractor says that he will correct this twist while casting the pillar by twisting and holding it during the moulding process, but this would introduce a torsion in the bars. Is the torsion OK or would it cause structural problems later? I may mention that the pillar design is at one edge of the isolated column foundation since our house is a middle house in a row of houses and hence the neighbour's wall did not permit isolated pillars in the middle of the foundation that is normally done. The middle pillar is also skewed to one end of the foundation because of a manhole. Hence all three pillars are at one edge of the foundation (6x4).
Thank you
Anuj Prakash |
Thu Feb 27, 2014 | Post #1 | Shanthakumar
Join date: Feb 2014 | Dear Anuj, Bars should be straight. All structural engineers consider straight bars in their design. However their are some more factors like rotation (moment) act on rcc pillar, minimum bars lapping distance , position of lapping btw pillars, tie ring design so on and so on...all structural constrain shall be supervised and approved by qualified structural engineer.
Regards, Shanthakumar, Architect. | |
Mon Mar 03, 2014 | Post #2 | S L Gupta (Civil Engg)
Join date: Mar 2008 | Dear Anuj What I under stand is that during foundation laying of columns the position of MS steel bars are disturbed and not truly in vertical in plumb. Now as per your contractor he wants to twist the bar on footing. It is difficult to tell remedy without seeing the problem at site.However tie 16 mm bar with this twisted rod WITH L-SHAPE MS rod having at least 3' vertical bar with L at bottom 9'' to 12'' and after cleaning the already laid concrete, lay new !;1.5; 3 cement concrete base at least 4'' to 6'' and than lay the pedestal. But I still advice if any civil engineer inspect the site, he will give good advice.
Pillar Work-Construction Questions (39) | |
Articles that might interest you! | | Column and Frame Structure Building Columns are used to support the beam or roofs and transfer the load to the earth. These serve the decorative purpose a.. | | RCC Roofing This roofing is very versatile and provides great protection. | | Demarcation/layout Procedure Baseline is marked on the ground either from centre line of the road or from any permanent building nearby | | Tips for Laying RCC slab / roof RCC slab laying is one of major step in any type of construction so it is mandatory to know all the points related to .. | | Mild Steel Bars in Cement Concrete Mild steel bars in reinforced concrete are one of the exceptional building materials. Reinforced concrete requires ver.. | | Water Storage Solution Storage of water in proper way is essential for drinking, cleaning, bathing, cooking purposes in our day-to-day life. .. | | Labor Guideline for Steel bars in RCC Every process needs proper guideline and expert person or team to manage in construction or in any field. Even working.. | | Gharexpert can save you money during construction Do you know almost all individual home construction projects in India take more money to complete than what people ori.. | | List of construction activities in sequence Before going for any construction do you know what the sequence of construction activities is? Here is a list of const.. | | Home Construction Safety There are several home construction safety tips which can be applied during construction of the house. This article wi.. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
