Home -> Forums -> Construction -> Basement -> RCC Roof before concrete floor
Mon Jun 03, 2013Total posts : 1
shilpa
shilpa
Topic: RCC Roof before concrete floor
I am constructing a commercial complex. It has basement and ground + 2 floors. We have finished column work, retaining wall and refilling of soil. Unfortunately because of heavy rainfall, the water is clogged in the basement floor. We are unable to do basement concrete floor. Our contractor is stating that he cant do centring work until we do concrete floor.
Our work is delayed too much because of rain. Do we have any solution for this, as rainy season seems to be never ending.
Thanks in advance  for the advice.
Tue Jun 04, 2013Post  #1
Dear Shilpa
         From the content give by you, I under stand that your basement columns and side wall is ready to lay the roof / slab of basement. Due to heavy rain your basement floor earth is become daldal/ mudy and your contractor saying that lay floor concrete. If the situation is like that as above than the solution is
  To lay lean concrete in flooring area for hard and stable ground for centering & shuttering.After completing the roof work and plastering than lay the floor on lean concrete according to your requirement.
25592
CURING TIME FOR RCC ROOF
4352
WHAT IS THE RATIO
2144
1443
1981
2403
roof concrete
2397
2195
Roofing cost for 3000 sqft 2nd floor roof
Last answer on 6/17/2015 6:56:38 AM. by JAI PRAKASH. Forum started by sira
3726
6364
kota Stone Roofing
3788
9844
2975
3256
Roof Concrete Strength
3966
Roof leakage
2030
4627
2314
9051
makan map
2757
17206
1978
2146
design of column
2263
2243
Underground water tank
2639
2753
foundation
2022
Full Plan Needed
3183
labour cost
3150
APP membrane
2788
1961
ffff
1860
4177
Selection of cement ..
3454
2001
Regarding construction
3144
Basement Water proffing
2002
Acid staining
Cooper
