Re. Pllar position and pillar strength.
Wed Nov 20, 2013
vignesh_mp
Topic: Re. Pllar position and pillar strength.
I have attached structural drawings for my house. It is G+2. I would really appreciate if someone can guide me about the column position and let me know it they are good ? In the front, my engineer have taken one pillar little bit along the center and other other pillar in the corner. Will it give enough support ?
I have marked all my questions on the image itself. Pls go through and suggest me if i have put one more coulmn on the left bottom corner of the house.
As they have already started construction, I appreciate the early response.
Thank you,
Vignesh,
ghar expert1.jpg on Wed Nov 20, 2013,
gharexpert2.jpg on Wed Nov 20, 2013,
gharexpert3.jpg on Wed Nov 20, 2013,&n
Wed Nov 20, 2013
Dear Vignesh
As per your query, you stated that the engineer made structural drawing and marked pillar on the drawing. At the time of framing the structural drawing, the load and safety are taken in to consideration. If you have any doubt than consult with your engineer, who is in best position to answer your question as he is aware about the project.
1979
Last answer on 10/13/2016 11:06:46 AM. by
Saneto Fernandes
4391
Last answer on 12/17/2020 5:55:40 AM. by
K Srinivasan
Last answer on 11/15/2016 1:51:43 AM. Forum started by
K Srinivasan
2950
Number and position of pillars
Last answer on 7/3/2020 10:41:58 PM. by
Ananda
Ananda
11057
distance between pillars
Last answer on 1/25/2021 8:45:40 AM. by
Irfan
ani
3391
plz tell me ideal position of dental chair n patient position in east facing den
Last answer on 7/3/2020 11:54:24 PM. Forum started by
dr mona
3793
Pandu
6437
position of pillars
Last answer on 11/18/2021 10:47:57 AM. by
ani
2596
What are the size available What about strength of main door price details
Last answer on 11/18/2013 3:35:39 PM. by
padma
3926
Distance between pillars
Last answer on 1/16/2014 3:37:45 PM. by
Ahmed
Badohi Singh
3610
Last answer on 8/12/2015 11:59:23 PM. by
jahangir
Last answer on 11/15/2016 2:10:38 AM. Forum started by
K Srinivasan
1844
Last answer on 2/16/2017 2:10:10 PM. by
MRINAL SENGUPTA
2530
Position of Kalpavirkha to be planted in east facing house & boring position of
Last answer on 7/3/2020 10:44:47 PM. Forum started by
RAJ KUMAR KALIA
2872
Position of staircase as per vastu
Last answer on 2/3/2011 10:41:29 AM. by
nith_piyush
Bhovotosh Deb
3510
i need to know about the lift position and can the lift come inside the house
Last answer on 12/31/2020 2:31:44 AM. by
Karan
vkausalya
2956
Last answer on 8/1/2012 9:53:21 AM. by
Ravi
J J Gupta
3505
Last answer on 11/8/2021 10:59:52 AM. by
nehamehta
J J Gupta
3031
Last answer on 4/1/2013 3:23:48 PM. by
akmurty1
kjeevanrao
5811
Rakeeb Rathor
3793
Pandu
9885
nasad
2670
Sreedhar
4628
ani
4143
Anamika
2866
lio
ringwang
R.Roy
5008
MANISH
3657
Arvind Bhaskar
premkumarlen
1865
carmenjames
r.n.misra
2801
Sharath Kurva
Sharath Kurva
2610
gk
2374
Adriano Peres
vamsi
2463
nuksung
2638
dayal
1808
TUNDE
3608
ragha
6254
suba
Brick Pillar
Types of Cement
Concrete Mix Ratio
Pooja Room Vastu
