Home -> Forums -> Construction -> Brick work -> Reinforced Hollow Concrete Block Masonry vs Traditional construction
Fri Aug 26, 2016Total posts : 1
Topic: Reinforced Hollow Concrete Block Masonry vs Traditional construction
Here one concrete brick manufacture has introduced concrete hollow bricks   where iron bars can be inserted vertically through the holes in the wall and fill using cement grout. They claim it will give the house better resistance to earthquakes compared to traditional solid brick  wall construction.
So, can experts compare  'Reinforced Hollow Concrete Block Masonry' construction with traditional construction (rubble foundation,rcc band,solid concrete brick wall, lintel band and rcc roof), and advise on which one is better?
Tue Aug 30, 2016Post  #1
Dear vinu
ADVANTAGES OF HOLLOW CONCRETE BLOCKS.
Highly Durable: The good concrete compacted by high pressure and vibration gives substantial
strength to the block. Proper curing increase compressive strength of the blocks.
Low Main
tenance, Color and brilliance of masonry withstands outdoor elements.
Load Bearing, strength can be specified as per the requirement.
Fire Resistant
Provide thermal and sound insulation: The air in hollow
of the block, does not allow
outside heat or
col
d in the house. So it keeps house cool in summer and warm in winter.
Economical
Environment Friendly,
fly ash
used as one of the raw materials.
Low insurance rates
Structural Advantages
In this construction system, structurally, each
wall and slab behaves as a shear wall and a
diaphragm respectively, reducing the vulnerability of disastrous damage to the
structure/building, during the natural hazards.
Due to the uniform distribution of reinforcement in both vertical and horizontal dir
ections,
through each masonry element, increased tensile resistance and ductile behaviour of elements
could be achieved. Hence, this construction system can safely resist lateral or cyclic loading,
when compared to other conventional masonry construction s
ystems. This construction system
has also been proved to offer better resistance under dynamic loading, when compared to other
conventional systems of construction.
Constructional Advantages
No additional formwork or any special construct
ion machinery is required for reinforcing the
hollow block masonry.
Only semi
skilled labour is required for this type of construction.
It is a faster and easier construction system, when compared to the other conventional
construction systems.
It is al
so found to be a cost
effective disaster resistant construction system, as explained in the
next section.
1998
Concrete Hollow Block Masonry
3433
2536
Civil Eng Stair Design
2536
2628
Precasted Concrete Blocks
Last answer on 12/31/2020 2:22:20 AM. Forum started by Girish
3842
9885
5018
2028
2992
3591
1797
2595
Last answer on 9/7/2012 4:18:47 PM. by S L Gupta (Civil Engg). Forum started by narsi vekeriya
2751
Reinforced brick wall construction
Last answer on 10/11/2011 6:33:52 AM. by S L Gupta (Civil Engg). Forum started by sunny420
4942
HOLLOW CORE CONCRETE SLABS
Last answer on 11/17/2009 12:39:06 PM. by Girish. Forum started by Girish
3046
Which would be a better options for apartments (medium and high rise) Concrete Tanks or Sintex Water tanks
Last answer on 10/20/2010 3:34:11 PM. by . Forum started by savietha
7513
Brick Advice Urgent
2185
1989
3669
wals
3264
compound wall
21875
3280
Bedroom Wardrobes information
2246
2206
1494
1965
1732
2224
2523
1502
1910
Brick or ACC block
1654
1702
4688
Brick wall on RCC slab
3929
2617
Concrete Decor
TMT
Ready
Ready Mix Concrete
Traditional
Traditional Style
Traditional style interior offers classy, relaxing and calm look to your home. Soft color schemes, paintings, wall han..
