Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Roof Beam & Roof Slab Thikness
Wed Oct 15, 2014Total posts : 2
R.R
R.R
Topic: Roof Beam & Roof Slab Thikness
What size of RCC beam and roof thickness required for span size 17 feet length by 17 feet width without any supporting Columns
Thu Oct 16, 2014Post  #1
12" thick beam is ok with roof thickness of 5".
Sat Nov 22, 2014Post  #2
ringwang
ringwang
The size of beam and slab , column should be depend on many factor not only the span of structure. you should consider the load on that structure. in your case i don't think 12" beam depth is enough. at least you should take 1.5' depth because your span is more that 5 mt.
5691
2053
12251
8419
Roof Beam crack
9893
3979
Roof leakage
2090
4664
Regarding Beam
3752
1906
2519
3271
Roof Concrete Strength
3837
Roof Beam
1768
Roof fabrication advIse
Last answer on 10/21/2015 11:43:50 AM. by S L Gupta (Civil Engg). Forum started by richlyn
8109
Wall on roof slab with no beam underneath
Last answer on 9/29/2020 11:34:24 PM. by S L Gupta (Civil Engg). Forum started by Joydeep
3890
Cost Estimation of Roof Slab with Beam Structure
Last answer on 4/24/2014 3:21:16 PM. by serin. Forum started by Subhajit Kundu
5486
Roof Slap & Roof Beam
Last answer on 7/4/2020 2:23:44 AM. by S L Gupta (Civil Engg). Forum started by Jahankumar
4952
2017
5810
3791
9883
2670
4626
4142
2865
5006
3655
1863
2799
2609
2372
2462
2637
1807
3607
6253
Cooper
Wood
Wood Roof Shingles
