Roof main vs distributuion?
Tue Mar 08, 2016Total posts : 3
Pooja
Pooja
Topic: Roof main vs distributuion?
Which side is to be considered main and which to be distribution to lay bars?
Our lohar says that shorter side is main but if we do that we would end up using lots of tmt overlaping in our case so they said to consider longer side as main
Thank you
 Pooja
Fri Mar 11, 2016Post  #1
Dear Pooja
        Shorter side is for main bars if difference is up to 2' than use longer side.
Sun Mar 13, 2016Post  #2
Pooja
Pooja
"if difference is up to 2' than use longer side"...I didn't understood this line. Please elaborate sir
Mon Mar 14, 2016Post  #3
Dear Pooja
        Use longer side as for main bar.
3210
Ferrocement channels roofing Vs Rcc slab
Last answer on 9/15/2021 9:04:11 PM. by S L Gupta (Civil Engg). Forum started by Sameer S Pawade
2497
3256
Roof Concrete Strength
13282
Marble Floor Comparison Required (Wonder Vs Katni Vs Dungri)
Last answer on 5/20/2014 12:04:53 AM. by Sunny Bansal. Forum started by Sunny Bansal
2258
RCC roof on other than pillar
Last answer on 11/26/2015 3:34:20 PM. by S L Gupta (Civil Engg). Forum started by Binoy Rabha
4995
8406
Roof Beam crack
1905
Llody metal roofing vs RCC slab for an office space of abt 1500 sq.ft. Which is
Last answer on 9/15/2021 9:07:42 PM. by S L Gupta (Civil Engg). Forum started by Suruchi
4462
2277
Suggest about diagonal plots facing ES facing, with main gate at east end and m
Last answer on 3/13/2012 1:14:13 AM. Forum started by Major Anil Kumar
2305
hi i want to know in which direction should be the main door of the house?where
Last answer on 11/18/2013 1:29:34 PM. by S L Gupta (Civil Engg). Forum started by manisha
2609
Vastu of the attached flat
858
in a vidisha plot, say,NW facing plot, how will you find pada for main door and
Last answer on 1/2/2021 5:19:12 AM. Forum started by Gopakumar Gopinath
2583
Yes sir main naya ghar bana raha hoon. Aur US main doors lagwane hain jis ke li
Last answer on 5/14/2015 4:18:22 AM. by JAI PRAKASH. Forum started by Krishna kumsr
2135
1820
1779
1633
278
82
29
26
31
31
30
28
28
29
25
25
21
31
22
30
27
23
Cooper
Aluminum
Aluminum Roof
Asphalt
Asphalt Shingles Roofing
