Roof related
Tue Mar 01, 2016Total posts : 6
Pooja
Pooja
Topic: Roof related
We are going to roof finally. Its 900 square feet. what steel bar size I need in roof? How much steel I need?
what steel bar size needed in stairs? I'm not building beam stairs for safety purpose
And yes, My constructor asked me whether to use lift or vibrator for roof lanter? Kindly suggest
Pooja
Tue Mar 01, 2016Post  #1
Dear Pooja
       The size of MS Steel bars and quantity is depends upon the design of slab/ roof.
However tentatively 900 to 1000 kg MS Steel bars is required and use 10mm and 12mm diameter MS Steel bars in roof/ slab.
In Stair slab minimum 12 mm steel bars is to be used.
For laying slab lift is required to lift the material from ground to slab and vibrator is used to compact the concrete mix after laying in the slab. Vibrator is necessary.
Tue Mar 01, 2016Post  #2
Dear Pooja
        If you want more information about ms  steel and concrete than see gharexpert website construction section in which sub section of brickwork structure concrete you will find many articles which give you more information. See link below
http://www.gharexpert.com/tips/articles/Construction/1730/Cement-Concrete-1730-Mild-Steel-Bars-in-Cement-Concrete_0
Wed Mar 02, 2016Post  #3
Pooja
Pooja
Post subject: Roof related
Thank you Mr. Gupta
I was also thinking that constructor is trying to save money by showing that he is using lift for me. And in reality he is trying to save his labour. He said that in lift the mixture is already very smooth but now I told him to use vibrator. Lift is his wish if he want to use or not or use his labour for the same purpose
Thank you once again
Pooja
Wed Mar 02, 2016Post  #4
Dear Pooja
      You should use mixture for mixing the materials and use vibrator for compaction the concrete mix. Lifting the material by labor or lift is no relation with mix and vibrator.
Thu Mar 03, 2016Post  #5
Pooja
Pooja
I understood your point Sir
Sat Mar 05, 2016Post  #6
10-12 mm in Lantel and stairs, 16 mm for any beam needed.
Use lift and vibrator.
love related problem in agartala__ 91-8769373431 kala jadu specialist baba ji du
Last answer on 12/14/2024 1:59:59 AM. Forum started by rupeshji
17
Last answer on 12/14/2024 11:35:46 PM. Forum started by rupeshji
Last answer on 12/17/2024 12:41:38 AM. Forum started by rupeshji
Last answer on 12/18/2024 10:31:39 PM. Forum started by rupeshji
2144
i need the term related with damp proof and its treatment
Last answer on 8/29/2012 5:01:18 PM. by S L Gupta (Civil Engg). Forum started by abhijeet joshi
2903
I am very appreciated for downloading your interior home design and hope that it
Last answer on 7/3/2020 11:27:09 PM. Forum started by Asraf Mallik
2176
give me siggestions related to concept?wat are the points kept in mind while des
Last answer on 12/31/2020 2:39:33 AM. Forum started by richa
1981
is this plot is lucky or wheather it is correct related to vaastu?
Last answer on 7/3/2020 10:44:55 PM. by sabina vanjani. Forum started by balaji
2616
final bill
Last answer on 7/3/2020 10:03:19 PM. Forum started by chethan
8420
Roof Beam crack
2371
Roof construction
2850
12251
3980
Roof leakage
2054
4647
2158
1837
Cooper
Aluminum
Aluminum Roof
Asphalt
Asphalt Shingles Roofing
Wood
Wood Roof Shingles
