Home -> Forums -> Interior -> Bathroom Accessories -> SANITARY WARES
SANITARY WARES
Tue Nov 19, 2013Total posts : 2
Topic: SANITARY WARES
Dear Sir
I am little bit confused about which one to select for my WC toilet, my contractor is suggesting to go for wall mounted one where as my friend suggests to go for floor mounted one because it is easy to maintain(because the wall mounted  WC tank is fixed inside the wall and the tiles has to be removed in case of any malfunction ). Could you please help me on this.
Thanks and Regards
Unni
Tue Nov 19, 2013Post  #1
Dear Unnikrishnan
           In my view floor mounted is better option.
Fri Nov 22, 2013Post  #2
Floor mounted WC is more durable.
Bathroom Accessories-Interior Questions (31)
3376
New House Construction
Last answer on 12/31/2020 2:45:48 AM. by srinivas reddy. Forum started by srinivas reddy
1192
Tiles Purchase
Last answer on 2/17/2017 12:08:10 PM. by S L Gupta (Civil Engg). Forum started by yasothabalanr
1908
2284
great design,but a little bit compacted,more space,less wares,that is well arran
Last answer on 3/31/2010 6:29:15 PM. by Ajit Tareeka. Forum started by joel
3654
2720
1390
which sanitary fitting are best in three companies - jagvar,sera,hindware which
Last answer on 8/8/2017 11:59:24 AM. by S L Gupta (Civil Engg). Forum started by vinod kumar garg
2014
space parameter for sanitary fittings
Last answer on 1/23/2016 8:28:13 PM. by JAI PRAKASH. Forum started by sandeep yadav
2594
JOINERY WORKS
2399
Sanitary Piping
Last answer on 5/17/2011 11:54:05 AM. by P. Panchal. Forum started by Gautam Aggarwal
2820
Last answer on 2/13/2012 3:19:03 PM. by PR Jawahar. Forum started by pallubc2
2268
Last answer on 5/26/2012 8:18:55 AM. by S L Gupta (Civil Engg). Forum started by hafiz
1630
Which arrangement of sanitary items is the best for the bathroom layout attached?
Last answer on 7/3/2020 9:38:05 PM. by S L Gupta (Civil Engg). Forum started by vinu
1614
What r the materials avaiable for hiding sanitary pipes and bath windows of a so
Last answer on 2/19/2014 12:24:30 PM. by S L Gupta (Civil Engg). Forum started by satish
1482
i want to build up commercial cum residential biliding in which ground floor sho
Last answer on 12/17/2015 2:52:33 PM. by JAI PRAKASH. Forum started by omprakash
1316
Last answer on 12/14/2015 12:01:37 PM. by S L Gupta (Civil Engg). Forum started by ramkrishan86
3238
2564
Cost difference between the variuos fittings
Last answer on 3/22/2011 3:07:37 PM. Forum started by dasaribalu
2025
Cellar is good or bad ?
Last answer on 6/16/2015 4:34:12 AM. by JAI PRAKASH. Forum started by kishore
1970
From where can I get this wall mount sink faucet???
Last answer on 9/16/2021 4:08:33 AM. Forum started by Bhavna
3601
Plz tell me that how i can give a glass partition?
Last answer on 3/14/2021 10:09:19 AM. by Gunjan Utraja. Forum started by tanu
2491
Where can i find this type of Wash basin.
Last answer on 12/31/2020 2:31:56 AM. by Gunjan Utraja. Forum started by Eber
1297
how much cost of these item
Last answer on 5/18/2016 11:21:04 AM. by S L Gupta (Civil Engg). Forum started by Abraham
2294
if isend the size of my bedroom and cupboard can anyone help me with the colour
Last answer on 1/23/2016 8:43:43 PM. by JAI PRAKASH. Forum started by Razia Amin
2238
Good and latest Bath Room Wall Mixer
Last answer on 6/10/2013 6:00:38 PM. by elinahenry. Forum started by raghuam
2645
Installation of a normal bathtub
Last answer on 9/9/2012 11:00:41 PM. by PR Jawahar. Forum started by raghuam
4495
Suggest Geyser for hot shower and Bathtub.
Last answer on 8/22/2012 10:21:07 PM. by vamsee. Forum started by raghuam
1640
Hi,I would like to know where can I find this type of wash basin with light.I wa
Last answer on 2/13/2012 11:56:53 AM. Forum started by mody kavita
1796
from where icould bath accesries
Last answer on 8/24/2011 2:38:10 PM. Forum started by dr vipin sharma
1955
What is this thing called (in the picture)? It looks to be towel dryer. How mu
Last answer on 7/12/2011 1:51:02 PM. Forum started by sumit dua
1759
If we design this same bathroom then how much does it costs?
Last answer on 3/29/2011 1:50:48 PM. Forum started by rupali
Sanitary
Which are space parameters for plumbing and sanitary fittings?
The following are various space parameters for plumbing and sanitary fitting:
General
Post
Post Painting Works
Various
