Home -> Forums -> Construction -> Foundation -> SIZE of column and also foundation
Tue Dec 13, 2016Total posts : 1
ringwang
ringwang
Topic: SIZE of column and also foundation
Here i have to Constructed the GODOWN 160'X55' having metalic sheet truss roof. the Column span is max 16ft . there is no column at cemter. please what is the column size and also reinforcement required. Also what is the foundation sizze required....
Here my contractor given 9"X15" cloumn size and also 4mo's 16 dia +4 no's 12dia reinforcement for column. foundation 4'X5'
Attachments: centerline godown (3 files merged).pdf on Tue Dec 13, 2016,&n
Thu Dec 15, 2016Post  #1
Dear Ringwang,
          The size of column and MS Steel bars and foundation is design with bearing capacity of soil and loading condition. It is better if you have proper design from structural engineer. However on reading the size of column and steel bars seem to be on lesser side. The minimum size of column should be 12''x15'' or 12''x18'' with 4nos 2omm and 4nos 16 mm dia bars with cement concrete mix 1;1.5;3 i.e M20.
1872
3776
2943
Need suggestions
15718
8932
6359
Column placement for house
2991
1923
2734
6530
3495
5193
2139
8948
Last answer on 9/11/2020 2:17:26 AM. by hemant. Forum started by hemant
4727
tie beam obsolete
3325
Column footing size
Last answer on 7/4/2020 2:00:01 AM. by S L Gupta (Civil Engg). Forum started by Pooja
4635
1949
cost of construction for large span of 60'
Last answer on 10/30/2014 12:27:22 PM. by Amit Hasija. Forum started by amit jain
2767
2656
Pillar
2126
Curing urgent
2346
structure work
5150
Pillar foundation
new house
2806
building a house
1980
Construction Agreement
3082
Foundation
2259
Foundation
1464
10029
3647
Foundation
2102
Structure proof checking
2545
Foundation design
2430
2455
Saria and cement
3634
Wall Thickness
2659
3144
13244
Steel Type
Designing
Designing a Foundation
Right size cupola
What is binding wire
