Home -> Forums -> Construction -> Water -> Salt water
Salt water
Mon Jun 03, 2013Total posts : 2
muthuraj
muthuraj
Topic: Salt water
I am constructing a house in Chennai, pallikaranai.
The ground water in this area is very salty if we go for a borewell beyond 30 feet. So I was advised by nearby neighbors to dig a well. As per that I dug a well up to 21 feet. The water is comparatively less salty.
1.       Apart from rain water harvesting, kindly suggest me what are all the steps I should do to improve the quality of water in the well.
2.       If I plan for a small water treatment plant for the well water, kindly advise what are the steps I should do and what type of treatment method I should adopt. (suggest on cost basis also).
3. Any other
Tue Jun 04, 2013Post  #1
Dear Muthuraj
        You should contact water treatment department, they shall tell you about water treatment after taking the sample of your well water.
Tue Jun 16, 2020Post  #2
Salt water used for making or preserving food, is usually saltier than sea water and is called brine. Drinking sea water alone is dangerous. A summary of 163 life raft voyages showed the risk of death at 39% for those who drank seawater, compared to 3% for those who did not. Experiments on rats showed the danger.
they usually say they are testing the salinity of the water: salinity is measured in parts per thousand or ppt. Most sea water is about 35 ppt salt. Salt lakes can be up to ten times as salty. Above that level precipitation creates a salt plain.
Salt water is more dense than fresh water. This means that it has more matter per its volume. Fresh water has a density of 1 g/ml, while salty seawater has an average density of about 1.025 g/ml.
2617
1541
Dear sir,our bore well water available with 1650 ppm salt content.please suggest
Last answer on 5/9/2016 11:04:57 AM. by S L Gupta (Civil Engg). Forum started by ananth
1961
water / salt in walls
Last answer on 3/25/2014 4:46:23 PM. by Abhishek Garg (Builder & Engineer). Forum started by Mrs Francis
3370
1523
there is too much salt in the ground on which our house is constructed.due to th
Last answer on 9/2/2014 10:27:25 PM. by JAI PRAKASH. Forum started by Rohini SINGH
2180
pile work
5056
6414
2543
water softner
2388
3968
water proofing of water tank
6272
Water Tank Quality
3120
2792
Last answer on 7/3/2020 11:53:31 PM. Forum started by mamta
2072
Dear Sir,We get water supply from city corporation
Last answer on 5/27/2012 8:33:01 PM. by Raghavendra. Forum started by Raghavendra
3803
2766
1620
where is water bouring
Last answer on 12/30/2010 9:07:12 PM. by S L Gupta (Civil Engg). Forum started by king jain
3177
Sump construction
2139
Question Regarding Borewell
1967
Over Head Water Tank
3129
Importance of Water
10179
2495
1887
water tank motor capacity
2754
Submersible pump - Bore
2358
2549
Water for Construction
60
60 Tips to Save Water
Vastu for Water Tank
Rain
Rain Water Harvesting
Preventive
General
