Home -> Forums -> Construction -> Drainage , Sanitary System and Plumbing -> Sanitary Appliances And Their Specifications
Mon Feb 13, 2012Total posts : 2
pallubc2
pallubc2
Topic: Sanitary Appliances And Their Specifications
Which is the better loo, S-trap or the P-trap?
The comment above talks about the article   "Sanitary Appliances And Their Specifications"
Tue Feb 14, 2012Post  #1
Dear Pallubc2
          S-trap is used for out let through the floor where as P-trap is used for out let through the wall.
Tue Feb 14, 2012Post  #2
PR Jawahar
PR Jawahar
Post subject: Wall hung toilet is better for cleaning floors
If you could choose wall hung type as shown in an attached sample picture, it would help a lot to keep the floors clean. However you need to get a good plumber who knows the job and fixes this well to the wall to have a firm fixture. Obviously in this case it would be a P-trap.
Attachments: wall hung toilet picture.bmp Tue Feb 14, 2012,&n
Drainage , Sanitary System and Plumbing-Construction Questions (39)
1906
1389
which sanitary fitting are best in three companies - jagvar,sera,hindware which
Last answer on 8/8/2017 11:59:24 AM. by S L Gupta (Civil Engg). Forum started by vinod kumar garg
2014
space parameter for sanitary fittings
Last answer on 1/23/2016 8:28:13 PM. by JAI PRAKASH. Forum started by sandeep yadav
2593
JOINERY WORKS
2718
3258
2096
specifications of building materials used in construction industry
Last answer on 9/6/2015 12:27:20 PM. by sanjay agarwal. Forum started by Star Koziba Leladi
2660
sir want the detail specification of acp cladding , such as thicknesss of sheet,
Last answer on 1/17/2013 12:27:08 PM. Forum started by somashekhar
2897
2416
can u give me the specifications of material shown in this picture and appox. ar
Last answer on 7/3/2019 12:31:26 AM. by Ajit Tareeka. Forum started by romaadhikari
2511
1626
Good morning ... can u please let me know the cost,specifications and estimation
Last answer on 10/17/2016 12:12:48 PM. by S L Gupta (Civil Engg). Forum started by syed ameeruddin
1087
Home appliances
630
Useful home appliances
Last answer on 11/12/2021 9:49:09 AM. by Asecrizur. Forum started by Quovino
2671
Kitchen Appliances
Last answer on 1/27/2013 10:14:53 PM. by kcantony. Forum started by Abhijit Chaudhuri
3375
New House Construction
Last answer on 12/31/2020 2:45:48 AM. by srinivas reddy. Forum started by srinivas reddy
2398
Sanitary Piping
Last answer on 5/17/2011 11:54:05 AM. by P. Panchal. Forum started by Gautam Aggarwal
2266
Last answer on 5/26/2012 8:18:55 AM. by S L Gupta (Civil Engg). Forum started by hafiz
1885
tap Connection
3627
sunken slab
2507
How to hire a plumber
3498
1675
2321
3860
flush toilet
1960
4721
Cost estimation for sump tank
2219
water supply
2042
Underground Water storage
2230
sewage pipes
2251
commode & flush type
1948
WC issue
5626
Over-Head water Tank
2337
Vastu for septic tank
2483
2474
Septic Tank Design
3387
3753
position of septic tank
Sanitary
Which are space parameters for plumbing and sanitary fittings?
The following are various space parameters for plumbing and sanitary fitting:
Kitchen Appliances
In kitchen, your cooking appliances dictate your life style. A perfect cooking appliance offers you to diminish clutte..
General
Electricity
Electricity Consumption of Various Appliances
Saving electricity not only adds to your money but will help thousands in demand of energy also.It’s duty of every cit..
What is binding wire
