Home -> Forums -> Construction -> Bricks -> Should I use quarry power or msand for making cement bricks?
Sun Jan 03, 2016Total posts : 2
Techman
Techman
Topic: Should I use quarry power or msand for making cement bricks?
Local contractor advised to produce the cement bricks on-site using small electric compressor/vibrator machine for my two storied house. I also prefer the same since the raw materials are supplied by me and he charges only for labour. He suggested the following materials and ration for good quality bricks:
For 300 bricks:
Metal - 1 Unit
Quarry Powder - 0.5 Unit
Cement - 5 Bags
I just asked about the possibility of using M-Sand instead of Quarry Powder for better quality and strength, his reply was Quarry Powder is the better choice for strength and quality compared to M-Sand.
Since he is not a qualified engineer, I'm here for experts opinion on this issue. Thanks in advance.
Mon Jan 04, 2016Post  #1
         The sand should be clean and coarser having Finesses modulus more 2.4 and silt contents should be less than 5%.
Coarse Aggregate
Coarse Aggregate consists of natural occurring stones (crushed, uncrushed or broken). It should be hard, strong, dense, durable, and clean. It must be free from veins, adherent coatings and injurious amounts of disintegrated pieces, alkali, vegetable matter and other deleterious substances. It should be roughly cubical in shape. Flaky pieces should be avoided. It should confirm to IS: 2383(I).
Grading of coarse aggregate
Coarse Aggregate should be either graded or single sized as specified in the table given below.
Characteristics of coarse aggregate
1. The coarse aggregate is clean, hard, non porous, free from lumps of clay and vegetable matter.
2. Water absorption of aggregate is not more than 10 % of its weight after 24 hours immersion in water.
3. Angular and roughly cubicle particles are ideal. River gravels make the best coarse aggregate.
4. Aggregate is chemically inert material.
5. Brick aggregate is not used in RCC work.
S. No.   IS Sieve size of Designation(mm)
 Percentage
40mm
passing
20mm
(by weight)
16mm
 for nominal
12.5mm
 1.   75   100  ----    ----     ----
 2.     37.5   95-100          100           ----     ----
 3.    19       33 - 70        95-100    100     ----
 4.     16   ----               ----    95 - 100         100
 5.   11.2       ----           ----  ----     90 -100
 6.    9.5        10 - 35     25 -35      30 - 70        40 -85
 7.     4.75    0-5     0-10      0-10          0 - 10
Deleterious substances in coarse aggregate
Coarse Aggregate should not contain any of the following deleterious materials.
  •  Pyrites
  •  Coal
  •  Lignite
  •  Mica
  •  Clay
  •  Alkali
  •  Soft fragments
  •  Sea shells
  •  Shale or similar laminated material
    NOTE: The maximum quantity of deleterious materials should not be more than 5% of the weight of the aggregate when determined in accordance with IS: 2386(I).
Precautions while using coarse aggregate
The following precautions should be taken while using coarse aggregate in RCC (Reinforced Cement Concrete) Work.
1. Aggregate should be stacked on a hard, dry and level patch of ground.
2. Coarse aggregate should not contain any material liable to attack steel reinforcement.
3. Aggregate which are chemically reactive with alkalies of cement should not be used.
4. Proper graded material should be used for achieving good bond stress.
5. Aggregate should be washed with clean water before the use.
Sun Jan 10, 2016Post  #2
Gupta Sir Thanks for the info.
2466
2349
Last answer on 7/11/2010 10:15:36 PM. by Anil Kumar Mishra. Forum started by satish singh
4179
GLASS BLOCKS / BRICKS
7513
Brick Advice Urgent
2695
4212
Selection of cement ..
1728
Last answer on 11/6/2015 12:41:03 AM. by JAI PRAKASH. Forum started by Techman
2815
Last answer on 12/31/2020 2:39:26 AM. by Shally. Forum started by kalpana
2417
2992
3591
3039
use of tmt bar
2018
3494
3041
1790
What are the special characters of different kind of bricks.Size of a cement bri
Last answer on 1/28/2014 2:44:37 PM. by S L Gupta (Civil Engg). Forum started by Dilip
1918
How do I clean cement and brick dust created
Last answer on 8/27/2021 7:09:02 AM. by S L Gupta (Civil Engg). Forum started by Satvinder kaur
6471
7513
Brick Advice Urgent
2880
Bricks
2794
brick calculation
2566
Cost of Brickwork
4895
2822
2350
3172
bricks
5660
2014
3238
5135
Use of Solid Concrete Bricks
1625
1341
1846
1480
1797
2967
fly ash bricks
2230
Hard
Skylight
Types of Cement
KITCHEN
"KITCHEN"THE POWER HOUSE
SOUTH-EASTCORNER IS SUPPOSED TO BE THE PLACE OF LORD AGNI,GOD OF FIRE.
