Home -> Forums -> Construction -> Outdoor -> Shuttering Material for roof slab
Tue Oct 16, 2012Total posts : 3
PR Jawahar
PR Jawahar
Topic: Shuttering Material for roof slab
Commonly wooden planks/steel sheets are used for roof slab shuttering. However this always doesn't give a good finish and also needs plastering, which causes further problem of chipping away in a few years.
An other alternative is to use Film faced plywood material, which would give an excellent finish and if done well the plastering could be even avoided and just a suitable painting could be applied directly in my opinion.
I would like to know how does the cost compare when we use Film faced plywood V/s conventional wooden planks/sheet steel. Is there any other alternative to get a good finish of roof slab and other shuttering works...
I've seen in some areas of Karnataka where they do a different kind of shuttering by use of  lean mix of cement+sand mortar over some fire wood timber shuttering and then casting the roof slab over this. The lean mix of cement sand mortar is then chipped & removed easily to get a good finish of the roof slab from under side.
Kindly provide your expert opinions
Wed Oct 17, 2012Post  #1
Dear Jawahar
                       For taking good finish of concrete slab, you may either use steel shuttering or ply wood shuttering. In steel shuttering, if steel plates have smooth surface without any dent or deposit of mortar and are properly placed in horizontal plan i.e. perfect in tiny squares and in straight edge then this will give best finishing. You would need to use the water controlled concrete mix and the slab should also be well vibrated. For making it even more smooth, one should place the plate in true plan and join the edges perfectly. After this the plates should be cleaned and oil should be applied on the surface.
Once the oil is applied, then a paper tape should be pasted on the joint of the plates. Care should be taken that steel bars are placed gently and proper care should be taken at the time of laying the concrete. Proper cover supports should be given under the steel bars and no disturbance should be done by labor when they walk on plates.
Also, the mix should be homogeneous i.e.the water contents of the mix should be within the limit
    In most govt. building where steel shuttering pattern is recommended by the architect, than you can see that this type of finish is available.
Shuttering using the shuttering ply wood is also good and gives good finish. Cost of this shuttering process is more. In steel shuttering plates the plates do not get damaged so the material can be used multiple times so rent of such material is less. However, the plywood gets damaged in the shuttering process and can only be reused a maximum of 15 to 20 times only if good care is taken for the material.
So, for an individual home construction plywood would be expensive unless your contractor can arrange plywood shuttering material.
Our experience is that even after using expensive shuttering material such as plywood if the labor does not take care while laying the concrete, one may end up requiring plaster on the surface. If for industrial buildings where an absolute smooth finish is not a prime concern or if you intend to cover the ceiling with false ceiling then cost of plaster can be avoided.
  As you stated for lean concrete and plaster on wooden planks, I am in view that you should apply white wash or apply oil on plaster surface so that the concrete will not stick on the plastered surface.
Fri Oct 19, 2012Post  #2
PR Jawahar
PR Jawahar
Thanks for your effort Mr.Gupta  in giving a long detailed response
Wed Nov 08, 2017Post  #3
         If you do not want gypsum plaster or false ceiling. Than
   Beside curing of plaster, for doing plaster you should  protect the furniture from plaster mortar dropping at the time of applying plaster on roof ceiling. To protect that you should cover the furniture with polythene  etc. Now for curing you should adopt the curing method by 4'' or 6'' painting brush and apply water with brush like paint but this will be expensive but save your furniture.
2248
9893
951
The roof slab is layed with clean shuttering plates and some places probably due
Last answer on 7/4/2020 3:34:29 AM. by Surinder Singh. Forum started by Surinder Singh
2865
2276
2090
3752
1906
25607
CURING TIME FOR RCC ROOF
3979
Roof leakage
1553
Last answer on 6/7/2017 12:20:58 PM. by S L Gupta (Civil Engg). Forum started by Sandeep Vidwans
4010
labor rate for RCC work
42596
Labour Cost for Roof RCC work
4836
2503
What will be coast of slab 5" for area of of 450Sq feet. I want material cost l
Last answer on 10/12/2014 9:25:00 PM. by SANJAY DUSANE. Forum started by milind
2557
1066
1504
Last answer on 10/31/2017 12:00:07 AM. by S L Gupta (Civil Engg). Forum started by div
1763
2865
Steel calculation
1758
6355
11377
10720
Life span of RBC lintel roof
2090
Foundation
3569
R.C.C. column in Sqft
2279
Plumbing works
1587
New 4 storey building design
1904
earth filling under floor
1773
want a parking
2404
2268
2565
foundation plan.
Last answer on 12/15/2011 2:31:13 PM. by Ishmael Mphande. Forum started by Patrick Salasini
2624
Last answer on 12/6/2011 7:58:37 PM. by Manish. Forum started by Manish
2501
Re-Construction
3013
cracks in walls
Centering
Cooper
