Home -> Forums -> Construction -> Brick work -> Spacing from outer edge of rubble foundation to concrete brick in compound wall
Thu Oct 27, 2016Total posts : 1
Topic: Spacing from outer edge of rubble foundation to concrete brick in compound wall
Usually the compound wall brick work is started leaving approx 2 inch space from the outer edge of rubble foundation, and people say its for the stability of compound wall. So, is it a must or can we construct compound wall  without leaving space after rubble foundation in order to get more space inside the compound?
Sat Oct 29, 2016Post  #1
Er.S.K.Jain
Er.S.K.Jain
Not must it is traditional design. at present many buildings construct without leaving space outside the boundry.
3470
Cost of concrete walls
9196
1814
1702
2840
Choosing the right type foundation and structure for house
Last answer on 9/30/2011 11:52:30 PM. by S L Gupta (Civil Engg). Forum started by Vinod
1983
Outer main wall to compound wall outer 10'9" distance. We constructed first flig
Last answer on 7/4/2020 4:23:29 AM. by S L Gupta (Civil Engg). Forum started by Prabu
3081
1509
3118
concrete brick or clay brick
2836
Compound Wall Construction
13651
2992
1684
2302
1846
1071
building 8" wall onthe slab will effecet the on the outer side
Last answer on 7/4/2020 2:02:31 AM. Forum started by Badhavath Rajeshwar
1341
3669
wals
3262
compound wall
21875
3280
Bedroom Wardrobes information
2246
2206
1494
1965
1732
2224
2523
1910
Brick or ACC block
2025
1653
1702
4687
Brick wall on RCC slab
3928
2617
Designing
Designing a Foundation
Concrete Mix Ratio
Small
Small Space Kitchen
