Brick work
Thu Nov 17, 2016
Topic: Standard thickness of grout in between concrete blocks in a load bearing wall
What is the standard thickness of grout in between the concrete blocks in wall construction? If the thickness is more, any issues other than usage of more cement and sand?
Fri Nov 18, 2016
Dear Vinu,
The thickness of the mortar joint in the wall should be from 10mm to 12 mm.
The issue is more thickness beyond limit is weakening the wall strength.
h.
4133
Last answer on 1/6/2022 11:48:27 PM. by
7260
Last answer on 7/4/2020 2:54:21 AM. by
gautam kumar
2213
Last answer on 11/13/2014 6:27:55 PM. by
Navaz
2153
3434
amit yadav
amit yadav
2808
Last answer on 11/2/2017 11:39:52 PM. by
Seraj Ahmed
2863
Last answer on 8/25/2011 5:27:13 PM. by
BATHISHA
2256
Last answer on 5/3/2016 12:27:42 AM. by
navneet
2617
COLUMN nd LOAD BEARING
Shivaraj
Shivaraj
1797
10048
manishkumar
manishkumar
1910
Brick or ACC block
Last answer on 10/7/2016 4:31:32 AM. by
gpeter
gpeter
1482
Structural Design loads and standards
Last answer on 9/29/2016 8:15:39 PM. by
john vali
john vali
3843
Last answer on 6/16/2015 4:28:50 AM. by
aladin
2122
Floor thickness
Last answer on 9/5/2014 11:40:46 AM. by
ravi pachipala
2428
RCC ROOF Requirements
Last answer on 5/22/2013 8:47:10 AM. by
Rajesh
Rajesh
3941
Last answer on 2/15/2013 11:15:40 AM. by
prassant kumar
prassant kumar
3426
Last answer on 1/15/2022 4:20:05 AM. by
kumar
4928
LOAD BEARING STRUCTURE
Last answer on 7/4/2020 2:56:39 AM. by
wals
shabbir ali
3264
compound wall
Last answer on 7/20/2021 1:24:04 AM. by
Satish Pingulkar
21879
Last answer on 7/3/2020 11:10:01 PM. by
Sambasiva Rao Ravuri
3280
Bedroom Wardrobes information
Last answer on 7/3/2020 9:26:49 PM. by
Meenakshi
2246
Last answer on 5/15/2017 1:39:35 PM. by
mknmohamed
2207
Last answer on 5/2/2017 5:25:23 PM. by
pramod
1495
Last answer on 1/16/2017 3:10:03 PM. by
1966
Last answer on 12/6/2016 1:58:54 PM. by
2225
Last answer on 11/3/2016 11:03:14 AM. by
atulbelokar
2523
1502
Last answer on 10/29/2016 2:54:11 PM. by
Er.S.K.Jain
1910
Brick or ACC block
gpeter
gpeter
1654
Last answer on 9/13/2016 2:59:02 PM. by
2153
1702
4688
Brick wall on RCC slab
Last answer on 1/27/2016 11:56:55 AM. by
rajiv sharma
3929
Last answer on 7/28/2015 11:31:41 PM. by
nithin
2618
Last answer on 2/20/2015 6:00:27 PM. by
gurmeet singh
Wall Decor
Cement Concrete
