Home -> Forums -> Interior -> Living room Doors and Windows -> Sunmica and doors
Sunmica and doors
Tue Feb 07, 2017Total posts : 1
Pooja
Pooja
Topic: Sunmica and doors
How r u ?
Need Your help! Please
We have selected pine wood flush doors and filling is also of pine wood.
. Is pine is good?
Secondly, What thickness of Sunmica should I paste on it? 0.8 or 1mm?
1mm is obviously good but still is saving money in Sunmica is worthy?
Price difference is too much
Thank you in advance
Tue Feb 07, 2017Post  #1
Dear Pooja,
         Flush door with pine wood is good and both grade of sun mica is good. When pasting process is good and done by skilled carpenter than use .80 to save money.
Installation/ fixing The Sun mica / laminates are fixed on the supporting base of ply wood, block board, particle board etc by adhesives. The supporting base should be sanded and free from dust, wax, grease etc. After applying proper adhesive the sheet of laminate is spread and hand rolled from centre to edge and remove all air bubbles.  To ensure adequate bond, sufficient pressure should be applied over the entire area of assembly.
Living room Doors and Windows-Interior Questions (23)
2213
how to clean sunmica doors
Last answer on 7/15/2021 12:45:52 AM. by HardissonHard. Forum started by Anu
2086
Design for Furniture
Last answer on 7/3/2020 9:41:55 PM. by S L Gupta (Civil Engg). Forum started by Siddharth Gupta
1474
Hello,can you pls advice on following.1)is it ok to buy BWR grade local flush pi
Last answer on 2/7/2017 1:19:37 PM. by S L Gupta (Civil Engg). Forum started by Manish Chugh
2163
i want office furniture (desk cabin desk & cbinet storege)colour combination of
Last answer on 2/23/2022 1:50:41 AM. by seema tyagi. Forum started by savani
1373
Hello Mr S.L Gupta,i forgot to ask one thing in my previous question. which opti
Last answer on 2/9/2017 2:00:15 PM. by S L Gupta (Civil Engg). Forum started by Manish Chugh
2834
Sunmica query
Last answer on 4/18/2018 1:10:51 AM. by Navneet Jharia. Forum started by Siddharth Gupta
12581
can we paste the sunmica on the newly built wall without wood base as we r pasti
Last answer on 7/4/2020 2:04:05 AM. by ravi at Dalmia. Forum started by veeraraghavan
3436
sunmica
Last answer on 12/6/2012 10:52:25 PM. by shailesh kumar singh. Forum started by tanaji
1382
Hello, my house is 30 yrs old and all doors are made of shisham. Now we are doin
Last answer on 2/6/2017 12:02:13 PM. by S L Gupta (Civil Engg). Forum started by sachin
4152
s there any advantage on pasting a SunMica or Laminate at inner side of a wardrobe door?
Last answer on 2/19/2013 12:05:47 PM. by S L Gupta (Civil Engg). Forum started by Deepak Kumar Garg
2678
please give images for iron door in front of main wooden door,
Last answer on 11/18/2013 3:27:52 PM. by S L Gupta (Civil Engg). Forum started by nagaraja k.n.
2847
Can u pls send me price for upvc door and door frame.Thomas
Last answer on 7/4/2020 3:07:03 AM. Forum started by Thomas Rodrigues
1923
chick door
1638
1759
1266
3210
Door direction
Last answer on 7/3/2020 9:10:36 PM. by S L Gupta (Civil Engg). Forum started by Rohit Patel
2484
door design
Last answer on 2/14/2014 4:17:10 PM. by Navneet Jharia. Forum started by chethan
2425
door design
Last answer on 11/24/2021 10:01:15 PM. by S L Gupta (Civil Engg). Forum started by chethan
2619
Window Awnings
Last answer on 2/15/2022 5:24:59 AM. Forum started by Shel Jones
6652
Sliding Door Window
Last answer on 4/23/2021 11:23:23 PM. by S L Gupta (Civil Engg). Forum started by Snehal Shah
5335
I wants windows and door design
Last answer on 7/3/2020 11:34:08 PM. by S L Gupta (Civil Engg). Forum started by Prahlad Kumawat
3145
Door for First Floor sitout
Last answer on 7/3/2020 11:22:36 PM. by vinod singh. Forum started by yasothabalanr
What are various types of panel doors?
Single panel, Double Panel, Three Panel, Six Panel doors........
Panel doors can consist of one to six wooden panels; but this may be increased.Hollow core wooden doors are usually fo..
What is the specification of Garage door?
Door
Door and Window Frames
Advantages
Advantages
