Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> TMT bars
TMT bars
Sat Dec 19, 2015Total posts : 2
Pooja
Pooja
Topic: TMT bars
What is the relationship between kamdhenu ispat and kamdhenu kay2? which one to buy?
Mon Dec 21, 2015Post  #1
Dear Pooja
         Take the branded MS steel bars after reading there literature.
Thu Dec 24, 2015Post  #2
Two grades of same brand. Best is kamdhenu 10000.
2612
3753
1622
1588
2627
Whether 6 x 8mm TMT bars are enough for rcc belt over rubble foundation for 2 story house?
Last answer on 9/30/2016 2:16:48 PM. Forum started by vinu
3039
use of tmt bar
4069
steel requirement
3179
Last answer on 3/14/2021 11:13:22 AM. by S L Gupta (Civil Engg). Forum started by venkatesan.pt.
24765
3224
Size of TMT bar for RCC main slab and beam
Last answer on 1/27/2017 3:25:08 PM. by Rahul. Forum started by Rahul
1502
1200
Hi,TMT grades like Fe 550 and Fe 550D, what makes Fe 550D more ductile. Why is t
Last answer on 2/19/2019 11:14:50 PM. Forum started by Vineeth V
2220
For 1850 sq.ft flat roof ,what mm tmt bars used my hall size 21*21 and 11*17 and
Last answer on 8/1/2018 11:18:57 PM. by S L Gupta (Civil Engg). Forum started by satheesh
1529
1188
Hi, Is there any cost effective methods to hire bending machines for reinforceme
Last answer on 7/4/2020 4:22:17 AM. by S L Gupta (Civil Engg). Forum started by Betty Varghese
944
My house was flooded during the recent flood, what should i do to check structur
Last answer on 9/5/2018 1:28:37 AM. by S L Gupta (Civil Engg). Forum started by Malini R
1164
When we bought TMT bars for house, they said it was anti-rust. We had to stop ou
Last answer on 8/19/2018 11:54:21 PM. by S L Gupta (Civil Engg). Forum started by Vineeth V
2605
2015
stair case
Last answer on 8/16/2013 4:32:36 PM. by S L Gupta (Civil Engg). Forum started by SCK
5811
3792
9885
2670
4627
4143
2865
5006
3656
1865
2800
2610
2372
2462
2638
1807
3608
6254
TMT
HSD
Type
Dining
Dining Chairs and Bar Stools
What are the various accessories recommended for Aluminium doors?
Various accessories for Aluminium doors :Door Handles,Door Fasteners,Door Viewers....
Precautions
